295/60r15 D/R S/B what’s your combo/ times #2826955
09/30/20 02:51 PM
09/30/20 02:51 PM
CA.
RAY1969CARS Offline OP
CA.
Thanks Mopar or no car
Re: 295/60r15 D/R S/B what’s your combo/ times [Re: RAY1969CARS] #2827027
09/30/20 06:17 PM
09/30/20 06:17 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I have only been out a couple times with my Cuda, but it ran 10.77 @ 125 at Fontana, car is over 3800lbs with me in it. A '70 'Cuda, 493, Indy SR heads, .600 lift roller, 10.5 comp., 950HP on a Indy single plane, 2" header, 4.56 gear, pump gas, 91 octane swill. The car has CalTracs/springs/shocks.
The convertor is really tight and will only footbrake like 2000, so I leave at 1500, flashes a little over 3000.
When I ordered it I wanted to footbrake 3000 and flash 4000-4500, but didn't happen. When I ordered it I mentioned I maybe adding a Gear Vendor, so maybe they made it tight for that, Continental made it, 9.5", had it like 10-12 years I think.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 295/60r15 D/R S/B what’s your combo/ times [Re: johnnycuda] #2827060
09/30/20 07:56 PM
09/30/20 07:56 PM
Every converter I had Chris make for me was way tighter than we had talked about, all three whiney
Re: 295/60r15 D/R S/B what’s your combo/ times [Re: RAY1969CARS] #2827219
10/01/20 08:45 AM
10/01/20 08:45 AM
an8sec70cuda Offline
Do you mean the 295-65 or the 295-50 radial? I don't think they make a 295-60 drag radial.
I run the M/T 295-65, but not a small block. I've been a good bit quicker in the 1/8 mile since I ran the 8.91 in the 1/4...just haven't made a 1/4 mile pass lately.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 295/60r15 D/R S/B what’s your combo/ times [Re: RAY1969CARS] #2827252
10/01/20 09:53 AM
10/01/20 09:53 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Well, I have a 275/60/r15 tire small block (close enough??). It runs 1.38 60’, 6.44 @ 105.9, 10.19 @ 130.5 in cool air, 6.5x’s and 10.3x’s in the heat.
Combo: 67 Barracuda, 3250 lbs, 408 stroker, e85, ported Edelbrock heads, Hughes solid FT cam 264/268 @0.05, Victor intake, home built 750dp e85 carb, 13.1 compression, 727, TA manual valve body, 8” PTC converter, 8 ¾ (MO875), spool, 4.10 gears, Hoosier 275/60/r15 DR.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: 295/60r15 D/R S/B what’s your combo/ times [Re: FlyFish] #2827361
10/01/20 12:39 PM
10/01/20 12:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'm running almost identical times and mph on a 275 ET Street Pro. I drive it the way I race it save for shock adjustment in the rear to soften it up on the street.
'63 Dodge 330
11.19 @ 121 mph
