Aftermarket drip rail trim options? #2826945
09/30/20 02:27 PM
09/30/20 02:27 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
Looking into buying drip rail trim. I know that original trim is always best, especially for vinyl top, but in your experience which aftermarket brands are proven to be a good alternative?
Re: Aftermarket drip rail trim options? [Re: fatsat] #2827006
09/30/20 05:20 PM
09/30/20 05:20 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
What make & model,I don't think they repop drip rail trim,they may for cuda/challenger
Re: Aftermarket drip rail trim options? [Re: 71GTX471] #2827084
09/30/20 08:48 PM
09/30/20 08:48 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
70 Sport Satellite
Re: Aftermarket drip rail trim options? [Re: fatsat] #2827378
10/01/20 01:39 PM
10/01/20 01:39 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I bought a set from 521 restorations, they were nice, but too small for a vinyl top. In order to use any new mouldings for vinyl you need to grind, and then sand smooth the drip rails until they just snap on with your fingers. I would also warn you to only epoxy prime the rails, then mask them off so they get no paint buildup. When you install them, wear cotton gloves and do not beat on them. I have a set from classic industries, and they appear to be the same. I found a set of originals for mine with vinyl, for a non vinyl car these would be fine, with a pre fit.
Re: Aftermarket drip rail trim options? [Re: 4406bbl] #2827524
10/01/20 06:37 PM
10/01/20 06:37 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
There's 2 different versions those with & w/o vinyl top, vinyl top ones are wider in the mounting area where fit over drip rail, don't know if this is true or not but I heard somewhere that the vinyl top ones can be identified by some green paint markings on the back side.
Re: Aftermarket drip rail trim options? [Re: 71GTX471] #2828610
10/04/20 02:20 PM
10/04/20 02:20 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
That is correct, originals will have green or purple dye if they are for a vinyl top. The sizes I have found are as follows
Closed-C inside size outside size
.375 .460 .490 current repop
.420 .490 .520 some early repops
.380 .470 .505 non-vinyl originals
.430 .510 .540 vinyl originals
As you can see about .050-.060 worth of grinding and sanding on the drip rails and they will work.
Re: Aftermarket drip rail trim options? [Re: 4406bbl] #2831872
10/12/20 12:12 PM
10/12/20 12:12 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
No grinding for me, I already have the top installed. At this point I'm finding that all of my original trim is in good enough shape. The only piece I'm needing is the left side top drip rail piece. If anyone has one in good shape then let me know in a PM.
