Re: Stage V 440 to Hemi conversion heads
[Re: Mad_Scientist]
#282662
04/12/09 03:37 PM
04/12/09 03:37 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Would I just be better off to buy a crate Hemi
In a realistic senario?....Yes, while the stage 5 coversion heads were"great" back in their initial release, because Hemi blocks,heads,...generaly Hemi anything was scarce, and expensive.....these heads filled a niche,.......unless you really want something different, there's alot of work ahead of you, and $$$$$ to mount these heads on an RB or B motor.......plus down the road, if you need parts, they might not be available, readily?
you can save the up, and buy into a 426 crate for about $10K........or buy the peices as you can afford them from MP, or other Hemi suppliers, and build your own.........
[Re: Mopar_Rich]
#282663
04/15/09 04:47 PM
04/15/09 04:47 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
so is there a "KIT" price for everything??? There was a hot rod artical that had a price breakdown a few years ago but I cant find it now. I mean is it like $6K for everything except for pistons and intake? and is the stuff available?? Ron... and Dayclona where can someone get 426 crate for about $10K.. the cheapest I have seen lately is $12,900-$13,100 area ![](/ubbthreads/images/graemlins/shruggy.gif) do you have a connection ![](/ubbthreads/images/graemlins/coool.gif)
[Re: JohnRR]
#282668
11/25/09 04:48 PM
11/25/09 04:48 PM
I JUST bought a set of these conversion heads from Eric at StageV came with rocker, shaft and stands, No valves or springs. Total package was $3990.00 SO YES these Heads ARE available!!!! SUPER Product!! And it doesnt take a BUNCH of machine work to the block. Most can be done at home with hand tools!! AND ONE MORE THING you can use stock A B or C body motor mounts, You have to grind the front 2 bosses off the block on the drivers and use the top back bolt boss, cut the motor mount as it interfers with the header pipe and weld a strap to the lower section of the motor mount that will bolt to the oilpump for the lower motor mount to hold firm in place, Hope this helps clear things up!!!!
[Re: JohnRR]
#282671
11/25/09 05:39 PM
11/25/09 05:39 PM
Posts: 10,168 A Red State
SNK-EYZ
A Red State
For those unaware, these are not a super simple bolt on, they require some block work that has to be done right. The rotating assembly will be custom to, no kits currently available will fit them. The oiling system will almost have to be an external one, and you will need a bigger pan. The heads will hold a lot of oil up top, and it can drain a stock pan in a hurry.
Also, because your using a 440 block, its weaker because its not cross bolted. You might not think that's an issue until you bolt on heads that flow in the neighbor hood of 400cfm and the thing revs like a prostock engine. So now you have this big stroker kit in the block that revs like wicked in a less than appropriate block.....Thoughts to be considered when going down that path!
Hmmmm...sounds like there are a few other things that i didnt think about when considering those heads. Waaaay too much to change just to run those heads. A person would be better off just buying a real Hemi block and regular Hemi heads since all those changes would need to be done.
WINNER ding ding ding ... WINNER ... ding ding ding ...
It would be way easier to start with a Hemi block.
From what I understood from the original post he was hoping to bolt the Stage V Hemi heads onto an already built wedge short block. That would never work, wrong pistons.
Starting from scratch with a Hemi block would be far simpler. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Mad_Scientist]
#282672
11/25/09 07:59 PM
11/25/09 07:59 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
How many people have these heads and what did you have to do to your block to make them fit? Is it feasible to make the modifications to an assembled short block, or are we talking major machine work? How was the pricing? Would I just be better off to buy a crate Hemi?
Current setup is a mild 440 that is set up for street use, but I really want a Hemi instead.
Stage V
I missed that the first time around , no it's not fesible to to the machine work to an assembled shortblock and what do you mean by ASSEMBLED , you already have a set of HEMI pistons in it or where you thinking you could put these on a 440 type build short block ? definitely NOT , with a flat top piston if you even had 7.0 compression I'd be surprised . Hemi combustion chamber runs about 170cc, never mind the valves would probably hit the pistons because the valve reliefs aren't anywhere where they need to be ...
[Re: CRE2004]
#282678
11/26/09 11:30 AM
11/26/09 11:30 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
I've always thought a low deck, short stroke hemi with a long rod and a light piston would be fun to build with a big set of twins hanging off the front of it.
I thought of a 472 or 451 hemi-headed low deck for my 68 Formula S, but the intake & headers were the limiting factors. The 400's a strong block & w/a stud girdle & aftermarket caps, should be able to take mucho power. Would probably save 50 lbs or so over the 440 block. I remember Eric sent me an email last yr & w/ rocker gear, I think the bill was slightly over $5K.
[Re: Cab_Burge]
#282679
11/26/09 11:33 AM
11/26/09 11:33 AM
Well considering a new world block is $3500.00 VS a used 440 block for $100.00 (which is good to 800 HP) without 4bolt mains You are already $3400.00 ahead. Real hemi heads (bare) with rocker assemblies are $3500.00 bare minimum. for a total of $7000.00 for a real hemi. for $4100.00 You can have a 440 with hemi heads. And about pistons, You can get ROSS ARIAS or JE in 4.350 which is .100 over 426 off the shelf piston. Total cost of a 440 wedge conversion is about $8000.00 HALF of what a real hemi crate motor is. The 440 ends up a 446 cu in. without stroking it and will make WAY more HP the a crate hemi. For those who are curious, go to "Converting a Wedge into A Hemi" on google or yahoo. This explains all the block work that is needed. Nothing major, most can be done at home with hand tools.
[Re: 451Mopar]
#282680
11/26/09 11:43 AM
11/26/09 11:43 AM
JohnRR
I talked to them about 15 years ago, considering the conversion also, but is was expensive I think over $5K, and I thought you had to drill and tap the head bolt holes for 1/2" bolts? I also think they required external oil return lines to the oil pan?
I remember reading about it so I'm trying to figure out how the price went down for these ???
