Clock spring
#2826407
09/29/20 11:06 AM
09/29/20 11:06 AM
Posts: 8,236 fredericksburg,va
cudaman1969
fredericksburg,va
How important is a clock spring and what does it control-do. 2001 Ram Van, cluster gauges keep going dead to working going down the road. I’ve double checked all connections for corrosion and no contact, fuse box too. Been chasing this grimlin for months. No affect on the engine running at all
Re: Clock spring
[Re: cudaman1969]
#2826455
09/29/20 01:13 PM
09/29/20 01:13 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Thanks, found something on line about that like you said. I’ll keep searching for the culprit. If you are unsure if it’s the clockspring I would take note of the wheel position while you are driving, and what the electronics are doing...or not doing. The clock spring does not fail ALL devices at once, it’s just a ribbon cable wound like a spring in order to allow two turns of the wheel each way without ripping itself apart.
