Going to dyno - 6 pack jetting starting point?
#2826080
09/28/20 03:06 PM
09/28/20 03:06 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Freshly built 440 based 505” stroker build going to dyno in a few days. Just looking for starting recommendations for the jetting. I have read quite a bit on anything i can find on jetting on this setup, but i se some very different approaches. I’ll give a rundown of what i have and please give me your recommendations:
505”rb - 4.350” x 4.25” 2618 forged Icon piston 7.0” h beam rod Stock 71 block line honed, bored .030, torque plate honed, clean up decked 10.9:1 compr Comp hyd roller cam by Dwayne P 235 /241 @ .050” .589” /.571” lift. 112 lsa. (Power brakes) Stock (untouched) Cast Iron six pack intake Trickflow 240 heads with cometic .027” Fully rebuilt 1990 vintage dc carbs. (Both metering plates had staggered jetting and stamped 35 (.093” dr / .086” pass) Metering plates were replaced with quickfuel jettable plates. I installed 81 jet dr / 77 jet pass. Center carb left at 64’s Pvcr’s were staggered at .052” and .043” Automatic 727 with 2500-2800 stall 3.91 gear 71 cuda all steel body and factory.
This is going to be a street car only but run hard frquently. So, what jetting woukd you start with and woukd you keep it staggered? I know we will look at plugs after each pull, but just looking for the best starting point for this setup, because as you know, pulling these carbs off with the steel lines is a PIA. Thanks.
Re: Going to dyno - 6 pack jetting starting point?
[Re: Chargerfan68]
#2826104
09/28/20 03:38 PM
09/28/20 03:38 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
This is going to be a street car only but run hard frquently. So, what jetting woukd you start with and woukd you keep it staggered? I know we will look at plugs after each pull, but just looking for the best starting point for this setup, because as you know, pulling these carbs off with the steel lines is a PIA. Thanks. Set it up temporarily with rubber hoses, so you can tune it easier
[Re: Chargerfan68]
#2826161
09/28/20 05:05 PM
09/28/20 05:05 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
This is going to be a street car only but run hard frquently. So, what jetting woukd you start with and woukd you keep it staggered? I know we will look at plugs after each pull, but just looking for the best starting point for this setup, because as you know, pulling these carbs off with the steel lines is a PIA. Thanks. I would start with what you have. You're right in the middle of what I ran on the dyno. I tried richer and I tried leaner. In short, despite seeing the changes in BSFC, O2, and mass fuel as you would expect, the power and torque numbers were all withing the repeatibility of the dyno. I've run this set carbs on a mild 383, a hot 383, a mild 440 and a 500 similar to yours. It's surprising, for how often I changed jetting around in those applications, I settled on nearly identical jetting for all of them. In another case, we ended up with slightly larger jetting all around. But this was on Impastato's dyno in Michigan and the engine draws outside air in. It was litterly 5°F outside that day. Plus the motor had open 2" primary tube headers and a cam with about 90° overlap. Even with all that, the jetting was still not that different.
[Re: BSB67]
#2826195
09/28/20 06:21 PM
09/28/20 06:21 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Set it up temporarily with rubber hoses, so you can tune it easier For sure Russ, when you dynoed your 505, what was the power difference between the Holley SD and the 6bbl?
[Re: Chargerfan68]
#2826228
09/28/20 07:43 PM
09/28/20 07:43 PM
Posts: 4,206 New York
polyspheric
New York
NO experience! But... the stagger is to correct manifold flow differences, and I would keep it staggered until you know otherwise.
Boffin Emeritus
[Re: polyspheric]
#2826276
09/28/20 09:38 PM
09/28/20 09:38 PM
Chargerfan68
New York, USA
Thanks for the replies. Ok, so i am going to make up some steel fittings to use rubber hoses for ease of making changes. And i guess it sounds like i should start where i have it set now. Ill pull all 8 plugs after runs and check to see how distribution looks with this staggered setup. I just was under the impression that only the rear was staggared , but when i think about it, the front and the back has shorter and longer runners feeding opposite sides of the carb. So i guess that’s the reasoning for differing the front and rear plates. I have the outboards idle screws at 1/2 turn, and i’m showing just square on the transfer slot for center carb, which brought me to just about 1/2 turn on idle speed screw. The outboards also have 1/8” holes on the throttle plates already.
[Re: BSB67]
#2826337
09/29/20 05:56 AM
09/29/20 05:56 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
This is going to be a street car only but run hard frquently. So, what jetting woukd you start with and woukd you keep it staggered? I know we will look at plugs after each pull, but just looking for the best starting point for this setup, because as you know, pulling these carbs off with the steel lines is a PIA. Thanks. I would start with what you have. You're right in the middle of what I ran on the dyno. I tried richer and I tried leaner. In short, despite seeing the changes in BSFC, O2, and mass fuel as you would expect, the power and torque numbers were all withing the repeatibility of the dyno. I've run this set carbs on a mild 383, a hot 383, a mild 440 and a 500 similar to yours. It's surprising, for how often I changed jetting around in those applications, I settled on nearly identical jetting for all of them. In another case, we ended up with slightly larger jetting all around. But this was on Impastato's dyno in Michigan and the engine draws outside air in. It was litterly 5°F outside that day. Plus the motor had open 2" primary tube headers and a cam with about 90° overlap. Even with all that, the jetting was still not that different. Vince Impastato is one of the Best in the business IMO Machining to Dyno The Man has great Knowlege.
[Re: Chargerfan68]
#2826418
09/29/20 11:41 AM
09/29/20 11:41 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
That is going to be a sweet running motor. I like the long rods and the DC carbs too. I started out with 78's in the outboards with 37 squirters and 67 in the center carb with a 31 squirter. I'm still running a 2.5 power valve.
Do yourself a favor and install a wide band to aid with tuning. I found it to be the best tuning tool I've ever used for tuning the jetting.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2826461
09/29/20 01:32 PM
09/29/20 01:32 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I just did a similar package. icon piston,7.10 rod, 440 source ported head, scotty brown hyd roller cam. outer carbs did not need any jetting just the center carb richer. 32 total timing pump gas made 605 hp 655+ lb trq.
JAKES AUTOMOTIVE
[Re: fast68plymouth]
#2826485
09/29/20 02:46 PM
09/29/20 02:46 PM
BSB67
Prospect, PA
Set it up temporarily with rubber hoses, so you can tune it easier For sure Russ, when you dynoed your 505, what was the power difference between the Holley SD and the 6bbl? About 20 hp maybe a bit more at peak in favor of the SD. 6 pack ahead until about 3600. About a tie 3600 to 4300, SD after that to 6000. Average about 10 hp difference. SD had a 1" open phenolic spacer, and I worked a little harder (more jet changes/more pulls) on it than the 6 pack.
[Re: AndyF]
#2826538
09/29/20 05:24 PM
09/29/20 05:24 PM
Chargerfan68
New York, USA
Thanks guys.
Dyno day is Thursday. There are no wideband o2s, but 8 egt probes in each tube. Ill def post the results and findings. One thingbi didn’t nention here was the pretty horrible coreshift in the six pack intake. Not sure how much it will hinder, but it was the most i’ve ever seen on a manifold in my possession. About .175” on sides from what i recall. And the street diminator that is on it first for break in and first pulls has been very well port matched and plenum cleaned up along with smoothing of the runners. So, not sure how much of a true comparison it will actually be. But, i guess, stay tuned for the results.
Russ, was your six pack intake the one that was ported by hughes? Or was it untouched casting? And, was it cast iron?
[Re: BSB67]
#2826763
09/30/20 08:30 AM
09/30/20 08:30 AM
Chargerfan68
New York, USA
Okay. I lied. Just checked. My 6 pack intake port windows are opened to match the standard port gasket. Ok...thank you
[Re: krautrock]
#2827311
10/01/20 11:32 AM
10/01/20 11:32 AM
jbc426
West Coast, USA
I bet it wouldn't be too hard to find dyno numbers for a similar combo as this motor but with Edelbrock heads instead of the Trick Flow. will be some nice info for comparison. Here is another comparison of a similar build with Indy EZ's and a hydraulic roller. Attached is the dyno run shortly before I almost had a catastrophic failure due to valve train instability issues due to insufficient spring pressures etc I've since dropped the compression and switched to a solid roller with the help of Dwayne Porter. and run a valve train setup by Mike at B3 Racing. The replacement pistons weighed in at 528 grams to match the high compression ones I had in there, so it really spins up nicely. I never did get it back on the dyno, but this latest motor is the smoothest reving RB I've ever had. Notice how close the power is between the 4bbl Dominator and the 3 - 2's. http://www.hughesengines.com/TechArticles/3dynotest684hp500cid6pack4bbljcross012007.php
