Installing roof rail weatherstrip in e-body #2826021
09/28/20 01:02 PM
09/28/20 01:02 PM
Missouri
randavis Offline OP
randavis  Offline OP
Missouri
I am looking for info to install the roof rail weatherstrip on my 74 Challenger. I have looked in the FSM, but it doesn't show the Challenger, but it does show other models. I have the seals from DMT. Also, how do you adjust the anti-blow off clips?
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Installing roof rail weatherstrip in e-body [Re: randavis] #2826712
09/30/20 12:04 AM
09/30/20 12:04 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Start them off at the front lower edge where the screws are, then work backward.
As you install, periodically roll up windows to ascertain a good fit with glass.\
Also helps to "fully" seat the gaskets.
Don't use any type of adhesive.
There should be holes already there for those retainers.
Re: Installing roof rail weatherstrip in e-body [Re: randavis] #2837345
10/25/20 05:41 PM
10/25/20 05:41 PM
scotreilly
scotreilly
Did it come with it?
Kodi nox
