Re: How to repair a cracked bell housing?
[Re: satgtx]
#282567
04/09/09 02:59 PM
04/09/09 02:59 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
stop drill it, grind a V, mig it up.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: satgtx]
#282570
04/09/09 11:05 PM
04/09/09 11:05 PM
Posts: 18,157 Mass
DAYCLONA
Mass
cast iron bell,
If you have access to a AC/DC arc welder, there are special rods available, that require no preheat of the subject,....just grind a vee on both sides, if accessabile, and weld,.....Chronatron Welding Supplies,.....If I recall the rod is called Chronaweld universal cast iron rod #333, use the 3/16 electrode rod, as the smaller 1/8 rod dissapates to rapid, then grind and dress as required, if done properly, you can make an unidentifiable repair
