340 Header Gasket (copper or aluminum) recomendation #2824465
09/24/20 09:37 AM
09/24/20 09:37 AM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Hey folks,
Looking for copper or aluminum header gaskets for 340 standard port X head. Thanks!
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: T/A CARe] #2824472
09/24/20 09:54 AM
09/24/20 09:54 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Neither one by themselves will seal that well. You'll need to put some copper high temp rtv sealer on them. Metal to metal is either touching or it's not if you think about it. They don't have any give to them.
Other will say Remflex.
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: Neil] #2824475
09/24/20 09:59 AM
09/24/20 09:59 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I used Remflex on my J-heads with excellent results. The failed to leak when the passenger side header caught the trailer and was bent significantly. Tube to flange weld/seal broke, but the flange didn't leak. I can't imagine a standard style gasket surviving that. They are worth the cost and all I'll use in the future.
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: gzig5] #2824482
09/24/20 10:19 AM
09/24/20 10:19 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Remflex are the best I have used--they sealed on cheap headers that I could not get to seal with other gaskets.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: wingman] #2824572
09/24/20 02:00 PM
09/24/20 02:00 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Remflex, nothing else.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: GoodysGotaCuda] #2824596
09/24/20 02:37 PM
09/24/20 02:37 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
If you buy remflex you wont use another gasket. Just follow the instructions!
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: DJVCuda] #2824687
09/24/20 05:56 PM
09/24/20 05:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I gotta agree the Remflex will seal for sure. My question for other Remflex users. Have you reused the gasket? My Remflex gasket stuck to the headers when I removed them and they tore apart.
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: mopars4ever] #2824733
09/24/20 08:27 PM
09/24/20 08:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We have used the Fel pro graphite type gaskets with Excellent results on a multitude of applications. The same type of gasket is made by different companies. They are somewhat soft and crush when tightened. Every set of copper or aluminum ones we have seen, leak Could be the for a number of reasons but the graphite have always sealed in those same applications without changing anything but the gaskets twocents
BTW I have plenty more pictures like the one below beer
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: TJP] #2824757
09/24/20 09:34 PM
09/24/20 09:34 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I have had copper header and collector gaskets on my 340 w/ J heads since I put the car back on the road in 2002. No leaks, still working fine. I did not coat them with anything. (I have TTI headers.)
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: 19swinger70] #2825027
09/25/20 03:33 PM
09/25/20 03:33 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Regardless of who's gaskets you use, you have to look at the flange-to-head and mate up the gasket... to see IF it'll make physical contact and seal. Some headers, example Hooker 5115 Super comp (SB Mopar), have poor flanges with the factory welded beads not allowing contact with the gasket ports completely around their ports... NOTHING will then seal!... and you'll have to apply extra surface area of welding and or hi-temp JB Weld epoxy around the port so the gasket will have some contact.
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: mopars4ever] #2825530
09/27/20 06:14 AM
09/27/20 06:14 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
My buddy does reuse them. He builds demo derby cars and reuses headers on all the small block chrysler engines he's swapped from car to car. One set of headers has been on 6 cars in 11 derby's so far, I just bought some used TTi's headers and will be running Remflex on those.
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: Mopar Mitch] #2825635
09/27/20 01:04 PM
09/27/20 01:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
The part of your statement I bolded is critical and often overlooked. But I'm not sure the hi temp JB will take that kind of heat on a prolonged basis. I know fel pro does sell the graphite / composite material in sheet form if you have to make your own as we have had to on occasion beer
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: TJP] #2825668
09/27/20 02:38 PM
09/27/20 02:38 PM
GA
roadrunninMark Offline
GA
Whatever happened to the idea of cutting the header flanges to make 3 individual pieces? A lot of time that thick flange doesn't give and if something is slightly off, make sealing the headers a pain in the rear. If you cut the extra metal between the cylinders, except the two in the middle (for non hemis), you now have "floating" flanges and have some flexibility to them. Not to mention it may give you some more room for your spark plugs. You can even cut the gaskets down or leave them as one piece for easier installation.
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: TJP] #2825786
09/27/20 07:35 PM
09/27/20 07:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We still do it when needed but as MM said, step #1 is to check the port to flange sealing area. beer
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: TJP] #2825805
09/27/20 08:02 PM
09/27/20 08:02 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I don't know why there is some resistance to cutting the flanges as you say, RoadrinninMark??
I have posted that solution maybe 10 times over the years, it works just as you say.
Never a leak here.....
Joe
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: jlatessa] #2825863
09/27/20 10:51 PM
09/27/20 10:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have been real happy with the TTI Gaskets. They seal great and due to some transmission issues I have re used my passenger side one about 5 times now from pulling that header and have had zero issues.
68 Barracuda Formula S 340
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: Bad340fish] #2825864
09/27/20 10:57 PM
09/27/20 10:57 PM
GA
GA
Agree, Joe up
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: jlatessa] #2826024
09/28/20 01:14 PM
09/28/20 01:14 PM
moparx Offline
moparx  Offline
Joe
same here. i always cut the flanges. plus, drill one bolt hole per flange oversize. this allows the flange to "float" a bit during heating and contracting.
no leaks on even the thin, flimsy flanges.
i stole this idea from a member here years and years ago, and it just flat out works ! boogie
beer
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: moparx] #2826121
09/28/20 04:03 PM
09/28/20 04:03 PM
GA
GA
That's a new one for me, thanks X! beer
Re: 340 Header Gasket (copper or aluminum) recomendation [Re: TJP] #2827416
10/01/20 02:54 PM
10/01/20 02:54 PM
Mopar Mitch Offline
Mopar Mitch  Offline
I'm a former aftermarket gasket applications engineer from Fel-Pro... 22+ years from the 70s-90s... with my interest in Mopars, they allowed me to work on many of the Dodge/Ply/Chrysler applications.... it was a great fun time and a great company back then!
