Ran out of motor before stripe - new info
#282383
04/09/09 11:39 AM
04/09/09 11:39 AM
Posts: 482 Dirty South, MS
mopowered
Dirty South, MS
I have only been running 1/8th mile events since putting in 4.88 gears (with 31x10.5 slick) but tried to get my '75 Colt down the 1/4 last night during T&T. I made 2 runs before putting it on the trailer. 1st run was a 12.68 (1.8 60ft) shifting by ear and watching tach. All shifts were around 5500-5800. Valves started floating around 6200 in 3rd so I backed it down just a bit in order to make it to the stripe.
2nd run I tried to get more from each gear by shifting by tach. Had to shift by 6000 on 1st shift (valvetrain instability) and made it to 6200 on 2nd shift where I got some more vibration/instability. Barely made it thru the traps by the time I was pushing 6200 in 3rd. Ran a 12.8 on that run (same 60ft, 1000ft, lost .2 in 1/8th).
Had to trailer it due to oil seeping past front & rear intake seal (RTV only - gasket on the way) on high-rev pass. Motor has 509 cam w/bowl-ported 2.02 J heads, roller rockers, double springs on a stock 360 short block. MSD-6A, aftermarket dist, Demon 750, custom bigtube headers, 2800lbs w/driver, 4000 stall converter (727 footbraking).
I know the shortblock needs to be decked and/or aftermarket pistons to up compression to match the rest but I expect more out of the combo as is.
Any comments and/or suggestions would be appreciated.
Re: Ran out of motor before stripe - how best to help
[Re: mopowered]
#282386
04/09/09 11:50 AM
04/09/09 11:50 AM
Posts: 43,309 Bend,OR USA
Cab_Burge
Several things to check, the Tach, the valve spring pressures as well as the lifter preload It sounds like the lifters are pumping up or the tach is off, which I have seen more than once. Try setting the lifters with 1/8 to 1/4 turn of preload after backing the adjusters off enough to get some clearances on the pushrod and then tighten to zero preload and add 1/8 to 1/4 turn hot Makes some runs at 1/8 and then try 1/4 and keep experimenting until you find what your motor likes
[Re: Cab_Burge]
#282389
04/09/09 02:58 PM
04/09/09 02:58 PM
mopowered
Dirty South, MS
Wow I didn't realize how expensive the good valvespring testing tools were. Is there a common place to go borrow one? There aren't many professional engine building shops around here.
I plan on checking/setting my lifter preload this weekend as that only requires a clear head and some elbow grease.
I did notice that the MP 292/509 cam is listed as having a 2800-6200 RPM range. I'm guessing that is part of my problem.
[Re: Cab_Burge]
#282392
04/13/09 10:05 PM
04/13/09 10:05 PM
mopowered
Dirty South, MS
They are aftermarket adjustable (5/8 + hex) roller (shaft & tip) rockers. I was thinking that while on the base circle snug is when I can't roll the tip w/my finger or spin the pushrod anymore. I'll probably start with 1/8 of a turn from snug to start with.
