Low profile puller for aftermarket damper? #2823681
09/22/20 03:58 PM
09/22/20 03:58 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
Looking for recommendations for a low-profile flange puller, so I can remove my fluid damper without taking the radiator and Contour fans out yet again.
With the radiator/fans out, the one I've got has worked fine, but the jackscrew is just too long to get it in there otherwise.
Any thoughts?work
Re: Low profile puller for aftermarket damper? [Re: DrCharles] #2823812
09/22/20 08:16 PM
09/22/20 08:16 PM
measure & if a shorter bolt would fit in there & do the job you could grab one at your hardware store & grind the thread end to a tip
Re: Low profile puller for aftermarket damper? [Re: RapidRobert] #2823859
09/22/20 09:41 PM
09/22/20 09:41 PM
West Plains, MO
West Plains, MO
I thought it was a very fine thread (and possibly hardened too)? Anyway I could certainly see if they have anything similar...
Re: Low profile puller for aftermarket damper? [Re: DrCharles] #2823862
09/22/20 09:56 PM
09/22/20 09:56 PM
IMGTX Offline
IMGTX  Offline
I found out that the bolt from my pitman arm puller was the same thread and used it for the same reason. It saved me from pulling the radiator on several cars.
If you don't have one AutoZone and other places rent them for free.
Re: Low profile puller for aftermarket damper? [Re: IMGTX] #2823872
09/22/20 10:48 PM
09/22/20 10:48 PM
West Plains, MO
West Plains, MO
Thanks for the tip! I do have a pitman arm puller and the screw is exactly the same as my flange puller, just a lot shorter up
It might even fit once I remove the crank pulley scope
