Re: A727TF kickdown adjustment
[Re: John_Kunkel]
#2830587
10/08/20 10:16 PM
10/08/20 10:16 PM
Posts: 528 SW CO
HemiSportFury
SW CO
And if you haven't matched the throw at the carb to the travel at the trans you will still have the problem you started with.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: moparx]
#2831057
10/10/20 09:48 AM
10/10/20 09:48 AM
Posts: 211 Halifax, VA.
moparjack44
Halifax, VA.
OP, pictures of your transmission hook up would help, as others have said. Will try to post some pictures, I hope today? I am not good at posting pictures. Kinda computer challenged Speaking of pictures, would someone post a picture using the Buchillon kit?
K.I.S.S.
[Re: John_Kunkel]
#2831058
10/10/20 09:55 AM
10/10/20 09:55 AM
moparjack44
Halifax, VA.
The gear it's has no bearing on the TP linkage operation. If flooring the throttle moves the trans lever forward, the linkage is hooked up to the wrong side of the throttle lever. Time for some pics. Took me a while, but I figured that out. Lever know goes in right direction. On test drive, still would not kickdown (didn't think it would, lever moved in correct direction, but far from full back). Also on test drive, shift points worse. (1-2, 8mph, 2-3 15mph, and slipping.)
K.I.S.S.
[Re: moparjack44]
#2831076
10/10/20 10:55 AM
10/10/20 10:55 AM
Posts: 528 SW CO
HemiSportFury
SW CO
lever moved in correct direction, but far from full back Therein is your problem. Until you correct this your tranny is not going to function correctly. Driving it just increases your chances of damaging it. Hopefully you haven't already. Change the mounting point on the carb to a position further away from the shaft (more movement) or move the attaching point on the trans to a position closer to the shaft (less movement) or a combination of both.
[Re: moparjack44]
#2831146
10/10/20 01:37 PM
10/10/20 01:37 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Also on test drive, shift points worse. (1-2, 8mph, 2-3 15mph, and slipping.) For light throttle, those speeds aren't far off factory spec but is the slipping during the shift or after the shift is completed?
[Re: John_Kunkel]
#2831156
10/10/20 02:17 PM
10/10/20 02:17 PM
moparjack44
Halifax, VA.
Also on test drive, shift points worse. (1-2, 8mph, 2-3 15mph, and slipping.) For light throttle, those speeds aren't far off factory spec but is the slipping during the shift or after the shift is completed? During.
K.I.S.S.
[Re: moparjack44]
#2831168
10/10/20 02:59 PM
10/10/20 02:59 PM
moparjack44
Halifax, VA.
A OP, pictures of your transmission hook up would help, as others have said. Will try to post some pictures, I hope today? I am not good at posting pictures. Kinda computer challenged Speaking of pictures, would someone post a picture using the Buchillon kit? OK.Got some pictures, need instructions how to post. My camera skills no better than my computer skills
K.I.S.S.
[Re: moparjack44]
#2831817
10/12/20 09:19 AM
10/12/20 09:19 AM
moparjack44
Halifax, VA.
A OP, pictures of your transmission hook up would help, as others have said. Will try to post some pictures, I hope today? I am not good at posting pictures. Kinda computer challenged Speaking of pictures, would someone post a picture using the Buchillon kit? OK.Got some pictures, need instructions how to post. My camera skills no better than my computer skills Pictures on my Andriod cell phone. I have been able to email my pictures, but unable to find instructions on sending to this site? I checked the Help page, but didn't help.
K.I.S.S.
[Re: stumpy]
#2832226
10/13/20 09:37 AM
10/13/20 09:37 AM
moparjack44
Halifax, VA.
I see changing your page appearance?, staying logged in?, no reference to posting a picture?
K.I.S.S.
[Re: moparjack44]
#2832323
10/13/20 02:27 PM
10/13/20 02:27 PM
John_Kunkel
Rio Linda, CA
I see changing your page appearance?, staying logged in?, no reference to posting a picture? Here's what the reply page looks like (on my computer), click at the red arrow to get the next box.
