Re: sorry in advance tire wheel combo question [Re: Mopar Mitch] #2824154
09/23/20 03:19 PM
09/23/20 03:19 PM
AndyF Offline
AndyF  Offline
Originally Posted by Mopar Mitch
Actually, to keep the wheel/tire centered within the factory wheel well and, most importantly the on-center track width, the correct BS for a 9" rim is 5", then a 10" rim is 10.5".
Zero offset basically? I've always thought Mopar cars worked best with 1/2 inch of offset. So 5.5" BS on a 9 inch rim and 6.0" BS on a 10 inch rim. I usually start with 1/2 inch of offset on any Mopar I work on and then go from there. I keep a stack of spacers on the shelf so I can move the rim back out 0.125 or 0.250 to get things perfect.
Re: sorry in advance tire wheel combo question [Re: Kern Dog] #2826156
09/28/20 05:01 PM
09/28/20 05:01 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
IMO... for any B-body, Frankenduster's wheel tire setup is really good.... tire/rims wide enough and tall enough... correct rim backspacing is the key to make them fit properly.
Thank you, Sir !
The outer wheel tubs in these cars is a bummer though. The design makes for clearance problems with a lowered car.
I found these pictures online. Someone had forethought while doing quarter panel replacement.
Was done here locally by a shop in Newton, KS.
'63 Dodge 330
11.19 @ 121 mph
