Redrilled m1 magnum intake. Junk? #2823211
09/21/20 10:49 AM
09/21/20 10:49 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
I was at a mopar estate sale yesterday and bought some goodies. I saw this magnum intake and I grabbed it. The last owner decided to drill it for la bolts as well.
Junk now? I could plug the la holes pretty easily. Scrap pile? Some people should only have tools under strict supervision
Re: Redrilled m1 magnum intake. Junk? [Re: chrisf] #2823215
09/21/20 11:17 AM
09/21/20 11:17 AM
Kirkland, Washington
Pacnorthcuda Offline
I’d say it’s a wall-hanger. Why did he drill into the water passage?
Re: Redrilled m1 magnum intake. Junk? [Re: Pacnorthcuda] #2823220
09/21/20 11:36 AM
09/21/20 11:36 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If that hole is the only thing wrong, tap it and plug it.
Re: Redrilled m1 magnum intake. Junk? [Re: slantzilla] #2823249
09/21/20 12:41 PM
09/21/20 12:41 PM
moparx Offline
moparx  Offline
all those holes look like they could be tapped for tapered pipe plugs, providing of course, they are somewhat close to the hole size of "??" required for "??" pipe thread. example, drill size for 1/4" NPT is 7/16". you could then use square head aluminum pipe plugs with a good sealant [JB weld perhaps ?], then cut/grind the plug[s] flush with the casting surface.
lots of work involved though, to do this.
hopefully, you didn't pay much for that intake. unless, of course, you want/decide to use it on an LA block.
beer
Re: Redrilled m1 magnum intake. Junk? [Re: moparx] #2823255
09/21/20 12:46 PM
09/21/20 12:46 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I would think that Mr. TIG is your friend.
Re: Redrilled m1 magnum intake. Junk? [Re: chrisf] #2823273
09/21/20 01:04 PM
09/21/20 01:04 PM
IMGTX Offline
IMGTX  Offline
It isn't uncommon to have manifolds drilled for vertical and diagonal bolts so as to mount to older or newer engines. Those holes only see engine oil on the backside so a little thread sealant will do the trick.
Now the hole in the water passage is a puzzle. If you can get the hole in the water passage to plug and seal or weld it up you will be OK with that manifold.
twocents
Re: Redrilled m1 magnum intake. Junk? [Re: IMGTX] #2823276
09/21/20 01:10 PM
09/21/20 01:10 PM
^^^ might of added it for an aftermarket water temp gauge (& wanting to keep the OE one)
Re: Redrilled m1 magnum intake. Junk? [Re: IMGTX] #2823278
09/21/20 01:13 PM
09/21/20 01:13 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
thanks guys.
totally unsure why he did that. he passed away and his kids are cleaning everything up so no indication on what his plan was or if he had purchased it that way himself. it was a package deal so not into it too deep. may just cut some plugs out and weld the holes shut. or throw it away. lol the water jacket hole is more of a mystery, it is tapped but if i am welding up holes anyways that should get a plug too.
i saw a few more things around his place that had the same kinda left field ideas. kinda sad that he collected so much stuff to just leave for his kids to throw away. they arent car people so i got there after the third dumpster had left.
Re: Redrilled m1 magnum intake. Junk? [Re: chrisf] #2823436
09/21/20 08:21 PM
09/21/20 08:21 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I would only be concerned with the hole in the water jacket. You can buy manifolds that are drilled for both la and magnum engines, so I really don't see the issue.
Re: Redrilled m1 magnum intake. Junk? [Re: elmor353] #2823578
09/22/20 11:06 AM
09/22/20 11:06 AM
Guitar Jones Offline
The hole in the water passage is for a mechanical temp gauge sender. Pretty common, but there isn't a lot of material there so be careful if you plan to use it or plug it with a pipe plug.
Re: Redrilled m1 magnum intake. Junk? [Re: 6PakBee] #2824080
09/23/20 01:28 PM
09/23/20 01:28 PM
moparx Offline
moparx  Offline
correct. up
but does the OP have one, or know how to weld aluminum ?
if he has to send that intake out, it may cost more to repair those holes than it is worth. shruggy
beer
Re: Redrilled m1 magnum intake. Junk? [Re: moparx] #2824385
09/24/20 12:37 AM
09/24/20 12:37 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
correct. up
beer
no problem there. but like you say. might not be worth the effort for a $100? (maybe?) intake
Re: Redrilled m1 magnum intake. Junk? [Re: chrisf] #2824859
09/25/20 09:24 AM
09/25/20 09:24 AM
God's Country Maryland
GODSCOUNTRY340 Offline
By the looks of those holes it looks like it was factory drilled and he just hogged the lower portion out. Just weld a threaded fitting in the water port or plug weld it.
