Re: b body charging system.. [Re: IMGTX] #2823718
09/22/20 05:24 PM
09/22/20 05:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
just like a bulb... will read ground on either terminal because the filament makes the bridge. A bulb is not more than a controled short to become it on a light source thanks to oxigen absence to burn it out like it was a complete short to burn. Well, an alt is more less the same, with the rotor just like the filament in a bulb
Re: b body charging system.. [Re: NachoRT74] #2823825
09/22/20 08:35 PM
09/22/20 08:35 PM
canada
cwilson66 Offline OP
canada
put a new insolation washer under the second field terminal screw, and shes fixed thanks for all the help guys even tho this should have been pretty obvious. always learnin!
thanks
connor
Re: b body charging system.. [Re: cwilson66] #2824116
09/23/20 02:11 PM
09/23/20 02:11 PM
moparx Offline
moparx  Offline
happy to hear it was a simple fix ! up
beer
