Gen 2 Hemi piston identification #2822608
09/19/20 01:55 PM
09/19/20 01:55 PM
Suffolk,VA
dragracedr Offline OP
Suffolk,VA
I found a set of 4.5 bore Hemi pistons,P4876020, for a later build. I can't find the nominal compression specs for these after checking old MP catalogs and on line search. Dose anyone know what the advertised compression ratio would be?
Re: Gen 2 Hemi piston identification [Re: dragracedr] #2822724
09/19/20 08:33 PM
09/19/20 08:33 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Are you sure the last number is a 0 and not a 6?
http://www.moparonlineperformance.com/product-p/p4876026.htm
Re: Gen 2 Hemi piston identification [Re: Dragula] #2822911
09/20/20 01:30 PM
09/20/20 01:30 PM
Suffolk,VA
Suffolk,VA
No, unfortunately. The last number is a zero. I'm thinking these may be crate hemi pistons.
Re: Gen 2 Hemi piston identification [Re: dragracedr] #2822942
09/20/20 03:07 PM
09/20/20 03:07 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Selling new in the box part number P4876020 MOPAR 4.5 bore 4.15 stroke 12.5 to 1 HEMI pistons (set of 8). This makes 528ci. VROOM!! Comes with pins. 1.031"
Floyd Lippencott IV
Re: Gen 2 Hemi piston identification [Re: mr_340] #2822960
09/20/20 03:57 PM
09/20/20 03:57 PM
Suffolk,VA
Suffolk,VA
thank you very much!
