Page 2 of 3 1 2 3
Re: Fuel pressure before the regulator [Re: fast68plymouth] #2822697
09/19/20 07:07 PM
09/19/20 07:07 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
If you look at the regulator on the inner fender, you will see another regulator which the fuel just runs thru. I tapped into the fitting there for my inside gauge thinking it would read pump pressure. Didn't see a problem doing it this way as if i ever go back to my Dominator, the regular is right there. I get it, with a return it will only have what ever pressure i set at carb.
Re: Fuel pressure before the regulator [Re: mopar dave] #2822704
09/19/20 07:23 PM
09/19/20 07:23 PM
AndyF Offline
AndyF  Offline
I'd remove the regulator on the inner fender. Replace it with a union fitting and put the regulator back in a box on the shelf so if you go back to the Dominator you have it. Running two regulators in series like that is asking for problems. If you need a place to tap in for fuel pressure then use a union fitting with a 1/8 NPT port on the size.
Re: Fuel pressure before the regulator [Re: mopar dave] #2822744
09/19/20 09:21 PM
09/19/20 09:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Theoretically, should be at least double what you want at the carb to over come the G's on the launch....I am at around 20-22psi before the regulator, right off the pump last I looked.
Re: Fuel pressure before the regulator [Re: Dragula] #2823368
09/21/20 05:00 PM
09/21/20 05:00 PM
Mt Morris Michigan
Mt Morris Michigan
Thinking it’s time to retire my old SX fuel pump. Looking at a Magnafuel 275 and a 300.
Re: Fuel pressure before the regulator [Re: mopar dave] #2823379
09/21/20 05:41 PM
09/21/20 05:41 PM
I've used and ran both of those pumps up
If I was building a new car and needed a pump I would buy the 300 to start with up twocents
You and I both know we will want more power later so why not buy the bigger pump first work grin
My new Drag car has a Magnafuel 500 pump in it, hoping for over 1000 HP N/A luck
Re: Fuel pressure before the regulator [Re: Cab_Burge] #2823386
09/21/20 06:02 PM
09/21/20 06:02 PM
Mt Morris Michigan
Mt Morris Michigan
Cab are you using that pump with a return line or dead headed?
Re: Fuel pressure before the regulator [Re: mopar dave] #2823393
09/21/20 06:24 PM
09/21/20 06:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running the Magna fuel 300 for many years and even on 1 plus hour drives and it's a great pump and no return needed, it returns directly back to the cell .......
Re: Fuel pressure before the regulator [Re: Thumperdart] #2823459
09/21/20 09:39 PM
09/21/20 09:39 PM
Mt Morris Michigan
Mt Morris Michigan
Looks like a nice pump. Rated at 950hp, not sure how accurate the ratings are thou because my current SX 160 pump is rated to 1000hp. I read the manual for the MagnaFuel pump and says return can be at the pump or at the regulator. Looks promising any way.
Re: Fuel pressure before the regulator [Re: mopar dave] #2823511
09/22/20 02:32 AM
09/22/20 02:32 AM
I use the factory fittings on the pump to return to the tank, not from up front back to a stock tank or one with the tank, in the rear tsk
Re: Fuel pressure before the regulator [Re: Cab_Burge] #2823528
09/22/20 07:48 AM
09/22/20 07:48 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, but a couple things. Why do they make these return regulators if you can't return from the regulator? Other thing, the Magnafuel 300 says you can't run pump more than 1.5hrs at a time, whats up with that? I wouldn't normally, but never know.
Re: Fuel pressure before the regulator [Re: AndyF] #2823539
09/22/20 09:12 AM
09/22/20 09:12 AM
an8sec70cuda Offline
iagree I run 20 psi to my fuel log.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fuel pressure before the regulator [Re: mopar dave] #2823574
09/22/20 10:56 AM
09/22/20 10:56 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a Magnafuel 275 and have had issues with the seal on the shaft of the motor leaking. I had it mounted laying down so that may have an effect on it, although Magnafuels tech told me it could be mounted in any position. I got tired of replacing seals and took it off and put my old Holley Billet 150 back on.
Re: Fuel pressure before the regulator [Re: justinp61] #2823581
09/22/20 11:17 AM
09/22/20 11:17 AM
Mt Morris Michigan
Mt Morris Michigan
I read a bunch on reviews on the Magnafuel 275 that were not positive. Many leaking pumps or locked up.
Re: Fuel pressure before the regulator [Re: mopar dave] #2823586
09/22/20 11:48 AM
09/22/20 11:48 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Magnafuel pumps are good pieces for sure and I have used them many times. If you can swing it look at the Weldon stuff. It is a much better product than Magnafuel but you pay for that. Since we switched I wont go back to MagnaFuel. Plus Weldons regulators are nicer and the low pressure one at the carb is a simple turn of a knob.
https://www.weldonracing.com/
Re: Fuel pressure before the regulator [Re: Al_Alguire] #2823607
09/22/20 12:51 PM
09/22/20 12:51 PM
Mt Morris Michigan
Mt Morris Michigan
I looked at their stuff and I agree. I have read all good about Weldon. Too pricey right now, think I’ll get the Magnafuel 300 ordered today. Thanks guys
Re: Fuel pressure before the regulator [Re: mopar dave] #2823638
09/22/20 02:26 PM
09/22/20 02:26 PM
Dragula Offline
Dragula  Offline
I had a Magna 275 on my Duster, and had zero problems with it. Last year I switched up to a Magna 500 and had zero issues with that one. I was just too close to the limit I think on the 275 that it was time to update when a good used 500 came up I couldn't turn down. You have to have a good regulator with one of these....No cheap ones. Its a lot of pressure to hold back. My other fav is the A1000, I love those things. Great pump with great versatility.
Re: Fuel pressure before the regulator [Re: Dragula] #2823650
09/22/20 02:50 PM
09/22/20 02:50 PM
Mt Morris Michigan
Mt Morris Michigan
I have a Magnafuel 500 pump a friend gave me, but it needs a rebuild. I orders the Magna 300. I think it will be plenty.
Re: Fuel pressure before the regulator [Re: mopar dave] #2823688
09/22/20 04:07 PM
09/22/20 04:07 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have 18 psi at the pump and 6 at the carbs -8 to carbs with no psi drop at launch but i had some at 14psi. 1.40 60'
Re: Fuel pressure before the regulator [Re: mopar dave] #2823694
09/22/20 04:21 PM
09/22/20 04:21 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine locked up at the drag strip after about three years of street/strip use. I completely rebuilt it and after about six months it started leaking again so now it sits on the shelf. I'm not sure I'll ever use Magnafuel again. From what I understand the pumps are made here and the motors are made overseas.
Re: Fuel pressure before the regulator [Re: justinp61] #2823702
09/22/20 04:49 PM
09/22/20 04:49 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep, i have often wondered why people spend all that money on those, which i always hear tales of woe about. When a Holley black will easily satisfy the needs of 95% of the N/A street strip or bracket cars on the board, and are way cheaper and very, very rarely fail.
I know they are plenty capable of supporting a high 9 sec 3350 pound car, using a T brake.
Most foolish thing i have done( among many..lol) was getting talked into “ upgrading” my fuel system. I did, and didnt see a thousandth difference, except in my wallet.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Page 2 of 3 1 2 3
