Race gear lube recommendation............ #2822329
09/18/20 04:10 PM
09/18/20 04:10 PM
central Kentucky
moprod Offline OP
moprod  Offline OP
central Kentucky
9" Ford with a spool , wt and syn or not ? been some time since I have changed a gear setup for drag car.
[img] [/img]
Re: Race gear lube recommendation............ [Re: moprod] #2822362
09/18/20 06:40 PM
09/18/20 06:40 PM
PA
moparacer Offline
moparacer  Offline
PA
I have run Lucas 75/90 gear oil in everything from a 7 second dragster to my 11 second street car.
Not saying its the best, but its never gave me any problems and I can get it locally when needed.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Race gear lube recommendation............ [Re: moprod] #2822365
09/18/20 06:46 PM
09/18/20 06:46 PM
AndyF Offline
AndyF  Offline
I'd say it doesn't matter with a spool unless you're NHRA class racing. Any rated gear oil should work just fine.
Re: Race gear lube recommendation............ [Re: AndyF] #2822426
09/18/20 09:13 PM
09/18/20 09:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Amsoil Severe Gear. 75w90.
Re: Race gear lube recommendation............ [Re: CMcAllister] #2822510
09/19/20 09:11 AM
09/19/20 09:11 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
With a spool and non-syncro transmissions I like the RedLine shockproof blue stuff. It really hangs on the gears.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Race gear lube recommendation............ [Re: moprod] #2822529
09/19/20 10:29 AM
09/19/20 10:29 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
My preference is a full synthetic.
When using non-synthetic the first run of the day was always slower even when warming up the rear end on jack stands.
With the full synthetic not a problem. I have used Valvoline and Lucas without issue.
Re: Race gear lube recommendation............ [Re: 340Cuda] #2822531
09/19/20 10:35 AM
09/19/20 10:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I seen the same results in my car
wave
Re: Race gear lube recommendation............ [Re: fourgearsavoy] #2822620
09/19/20 02:30 PM
09/19/20 02:30 PM
Gus beer
I use the Redline brand Lightweight Shockproof blue/green colored synthetic gear lube in the blue labeled bottles, not the Super Lightweight red colored in the yellow labeled bottles, in my S/P car with a Mark Williams Dana 60 with 40 spline spool and axles using a set of stock 4.56 Dana pickup used gears, that lube flat works great, 1.24 60 Ft. so far launching off the trans brake at 5800 RPM up
Re: Race gear lube recommendation............ [Re: Cab_Burge] #2823095
09/20/20 10:16 PM
09/20/20 10:16 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
I've been running 75w140 synthetic, Haw much of a difference would it make switching to 75w90?
Re: Race gear lube recommendation............ [Re: Moparrob68] #2823139
09/21/20 01:31 AM
09/21/20 01:31 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
its funny i use the Lucas 85/140 mineral . That is what Strange supplied and recommended for my S60 with detroit locker . When i went transbrake i checked with them they said use the same . Daily driver / bracket racer
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Race gear lube recommendation............ [Re: Moparrob68] #2823301
09/21/20 02:01 PM
09/21/20 02:01 PM
Maybe some change, maybe not confused
I would try it to find out up
My car came with that green/blue lube in it, the former owner had ran a blown aluminum B1 on alcohol with 5.86 Pro gears in it and he told me he never had a gear problem wit that lube up work
I order what I thought was the same gear lube but I didn't know the correct part number and ended up ordering both the lightweight and super lightweight gear lube to have it when I swap the 4:56 for the 5:86 gears in the rear end.
That gear lube pours out of the bottle cold like ATF does shock up grin It is really good stuff, get you some of that up
I'm a little scared to try the super lightweight do to the old adage of not fixing what isn't broke work realcrazyshruggy
