Oil pickup in Gen II crate hemis #2822578
09/19/20 12:39 PM
09/19/20 12:39 PM
Sweden
MikeN Offline OP
MikeN  Offline OP
Sweden
I use a MP/ World Hemi block with the MP 6qt (1970 type) oil pan and pickup as recommended in the block instruction sheet. Pickup would fit fine if the pan was 3/8" deeper. Since this parts combination is common and used in many crate hemis I guess the problem has occured before. What is the tried and tested solution?
Re: Oil pickup in Gen II crate hemis [Re: MikeN] #2822673
09/19/20 05:24 PM
09/19/20 05:24 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
This won’t help you, but it’s a serious question......
Did MP actually build and sell and complete crate Hemis built from the World style block?
Re: Oil pickup in Gen II crate hemis [Re: MikeN] #2822826
09/20/20 09:14 AM
09/20/20 09:14 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
First make sure that you actually have the correct pan and pickup. Parts man could have thought all Hemi pickups are the same or all 70 pans are the same and substituted something he had in stock.
If they are correct then it would not be the first time I had to tweek a pickup.
