Re: Out with the old.
[Re: T-bar]
#2824513
09/24/20 11:41 AM
09/24/20 11:41 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I took the car out Sunday arvo for a cruise and had cooling issues, but i do only have 2 x 10" fans so I'll try 2 x 12" fans and try them. I"ll be a few weeks off getting it to the track due to work commitments Make sure you aren't moving too much water. Sometimes you need to reduce the water flow to allow the radiator to cool.
[Re: T-bar]
#2824821
09/25/20 06:02 AM
09/25/20 06:02 AM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
I will give the bigger fans and a modified alloy shroud a go first and see what happens if that doesn't work i will check into bigger radiator. Yeah i reckon i can get it down with 275's just going to take some planning. I couldn't get a small block Cuda to hook on those. Got flagged for going thru the traps side ways...
[Re: Dragula]
#2824852
09/25/20 09:04 AM
09/25/20 09:04 AM
Posts: 10,027 MN
JERICOGTX
MN
I will give the bigger fans and a modified alloy shroud a go first and see what happens if that doesn't work i will check into bigger radiator. Yeah i reckon i can get it down with 275's just going to take some planning. I couldn't get a small block Cuda to hook on those. Got flagged for going thru the traps side ways... Some guys go fast on a Redline Bias Ply street tire, and some can't get a 14x32 to work (myself included). It's all about power management.
69 GTX
68 Road Runner
[Re: INTMD8]
#2824889
09/25/20 10:53 AM
09/25/20 10:53 AM
Posts: 1,826 South Bend
John Brown
South Bend
Old wives tales die hard.....
[Re: camastomcat]
#2824940
09/25/20 12:38 PM
09/25/20 12:38 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
It's clear you didn't bother to read what I linked which makes me wonder, why ask the question if you aren't willing to learn the answer?
You're drawing the wrong conclusions from your experience.
If you want to know the answer to your thermostat question, ask again in a manner that is not condescending.
[Re: blowndart]
#2825017
09/25/20 03:19 PM
09/25/20 03:19 PM
Posts: 19,413 north of coder
moparx
Whether you need a thermostat or not, is really a matter of what you need to accomplish and the capability of your cooling system. If you need or want your engine to come up to a particular operating temperature as quickly as possible and stay at that fairly precise temp, (provided that you have a properly-sized and efficient heat exchanger (radiator)), you need a thermostat. That’s why all vehicles come with them as standard equipment. If your cooling system is not adequate to function properly with a thermostat (because they are a flow restrictor, even when fully open), or you need to operate at a temperature that is lower than what a typical thermostat is designed for, removing the thermostat might help you achieve your goal. You just lose the ability to control the coolant temperature (unless you’re using fan controls to control temp). If your cooling system is still not able to prevent an overheating condition after removing the thermostat, you need to improve the capacity/efficiency of the cooling system. i agree with the above, but the best results will have the fan, thermostat, and/or the restrictor [or none] working together as a team to get the desired results one is after.
[Re: moparx]
#2825036
09/25/20 03:44 PM
09/25/20 03:44 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
