1971 Cuda billboard marker lights? #28216
06/23/06 03:26 PM
06/23/06 03:26 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
What color "white" were the rear marker light housings painted on a '71 'Cuda with V6W "white" billboards? Were they GW3 "sno-white" or another shade of white?
Re: 1971 Cuda billboard marker lights? [Re: 6bblgt] #28217
06/24/06 05:12 PM
06/24/06 05:12 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
I guess nobody knows or cares what is correct?
Re: 1971 Cuda billboard marker lights? [Re: 6bblgt] #28218
06/24/06 05:34 PM
06/24/06 05:34 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I thought the bezels themselves were body color.
Re: 1971 Cuda billboard marker lights? [Re: buildanother] #28219
06/24/06 06:00 PM
06/24/06 06:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Should be body color.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1971 Cuda billboard marker lights? [Re: 6bblgt] #28220
06/24/06 08:52 PM
06/24/06 08:52 PM
Windsor, ON
Lemon_Twist Offline
Lemon_Twist  Offline
Windsor, ON
According to the guru, Galen, marker bezels on black striped cars should be matte black to match the billboard. I would assume the same holds true for white billboards. If I remember correctly that Sno White is the brighter of the two shades, that would be my guess for the correct shade to go. The other white had a bit of that creamy tinge to it which would not go well with the billboard.
Re: 1971 Cuda billboard marker lights? [Re: Lemon_Twist] #28221
06/24/06 10:43 PM
06/24/06 10:43 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
ive seen them both ways body color and bill board color personally mine are body color! id have the body shop do a spray out of both shades and pick whichever one matches better!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 1971 Cuda billboard marker lights? [Re: pnypwr] #28222
06/25/06 12:12 AM
06/25/06 12:12 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
judging by this FSM insert-doesn't say anything about light housing-they cut a slit in the decal and wrapped it into the inside of the fender panel-saw GG's article on it-have it somewhere-have seen both body color and decal color
Re: 1971 Cuda billboard marker lights? [Re: shakerjoe] #28223
06/25/06 09:54 AM
06/25/06 09:54 AM
I say all cars with strips, the marker should be the same color as the stripe.
Re: 1971 Cuda billboard marker lights? #28224
06/25/06 11:08 AM
06/25/06 11:08 AM
Attached is a closeup photo of an unrestored Billboard at the marker light. You can see the slit at the top corner where it was cut at the factory, and also, the marker light bezel is Black to match the Billboard. This photo was orignally posted by another member, so thanks to them for posting it (I forgot who it was).
Re: 1971 Cuda billboard marker lights? #28225
06/25/06 11:10 AM
06/25/06 11:10 AM
This photo is another photo I had of a White Billboard 'Cuda. The car has been restored, but the marker light bezel is White, same as the Billboard. Looks to be the brighter White color. Hope it helps.
Re: 1971 Cuda billboard marker lights? #28226
06/25/06 12:31 PM
06/25/06 12:31 PM
New Jersey Bada Bing
bremotorsports Online content
bremotorsports  Online Content
There is no question that original billboard Cuda's have the rear side marker bezels painted to match the stripes. "Matte" black (probably similar to, or even the same as the non-textured low-lustre rocker panel paint or radiator side panel paint) appears to be correct for black cars. My own car is a white billboard car, and even though 35 years have passed, the color appears to be Sno-White.
Also, for those who are not aware, the procedure for finishing and installing the rear side marker assemblies is unique:
All Cuda's came down the line and were painted with the side marker BEZELS installed only (No reflector or side marker lamp assy YET), and held in place by the galavanized retainers and "acorn" nuts.
When it was time for the billboard stripes to be installed on a car so designated, the retainers and nuts were removed and placed on the side. The stripe was applied, and during the application was slit to conform to the shape of the quarter panel. The second step was to push the excess stripe material through the side marker bezel hole in the quarter panel and then be trimmed on the inside. The third step was to install a NEW PAIR of PREVIOUSLY PAINTED bezels in the holes, and using the ORIGINAL RETAINERS AND NUTS, which still have BODY COLOR OVERSPRAY on them, back over the studs on the new bezels. These new bezels actually have the words "BLACK" and "WHITE" with corresponding numbers CAST into them. The final step involved the installation of the reflectors and side marker lamps. The set of bezels that came out of the car were certainly re-shuffled back through the system and re-installed on non-billboard cars. Those bezels would NOT have the words "BLACK" and "WHITE" cast into them. The overwhelming majority of used bezels that you will see on vendor tables at the major Mopar events will be this type. Occasionally, used "BLACK/WHITE" bezels turn up. As far as NOS, it is rare to find the "BLACK/WHITE" bezels in the box (I still need the right rear as NOS, but I have an NOS left rear). The bezels are identical otherwise.
My own car is a textbook example of this process. The bezels are painted white (with a bit of primer showing through on the trunk side of the bezels, but NO FE5 Red paint). The retainers and nuts have FE5 Red body paint on them. This was an original untouched one-owner car. I have also examined a great many original billboard cars and so far they are the same.
Does anyone have a pile of used rear bezels? You may be surprised at what you find!
Bill Rolik
P.S.
I will be happy to e-mail photos separately to anyone who would like to see my originals.
bremspts@optonline.net
Re: 1971 Cuda billboard marker lights? [Re: bremotorsports] #28227
06/25/06 08:56 PM
06/25/06 08:56 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Thanks Bill , after the first two responses I thought I was losing it.
anal 1971 Cuda 101? [Re: 6bblgt] #28228
06/27/06 07:09 PM
06/27/06 07:09 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
I checked and both rears are of the "black/white" casting variety. "Sno-white" they will be. V6W on a 3/71 built EV2 "tor-red" car.
I also checked the '70-'71 parts catalog (Jan '72 issue). I didn't find a listing for the "black/white" thing, but noticed that the reflector (4/70) and bezel (6/70) changed during the '70 model year. Anyone know what changed? Also are the lenses all the same for the side marker lamp, which when installed Left Rear and Right Front are upside down?
Re: anal 1971 Cuda 101? [Re: 6bblgt] #28229
06/27/06 09:09 PM
06/27/06 09:09 PM
mo71cuda Offline
mo71cuda  Offline
The black shown by arrow is the billboard
material
Re: anal 1971 Cuda 101? [Re: 6bblgt] #28230
06/27/06 09:18 PM
06/27/06 09:18 PM
IF (this is a big if) the change in bezel part numbers was supposed to be reflected in the "Black/White" casting upgrade, it apparently did not occur in actual practice. I have had (and still have) many individual bezels, and lamp assemblies, both packaged as early and late numbers, and out of all of that, I have only one NOS "Black/White" bezel. I do not really see any other differences in the bezels.
As far as the reflectors, the 70 cars had the type with an adhesive tape ONLY on the back. The line workers simply pulled the the cover off of the tape and stuck it in the bezel. But apparently, this was not sufficient over the course of time. The 71 style reflectors also have plastic tabs that pushed through holes in the bezels to properly secure them.
Regarding side marker lenses, as far as I can tell, all red rears are the same, and all amber fronts are the same.
Bill Rolik
Re: anal 1971 Cuda 101? [Re: bremotorsports] #28231
06/27/06 10:56 PM
06/27/06 10:56 PM
California
1970mopar Offline
1970mopar  Offline
California
I believe you will also find some very late 70' Cudas with the "71' style" reflectors.
Re: anal 1971 Cuda 101? [Re: 1970mopar] #28232
06/28/06 12:27 AM
06/28/06 12:27 AM
That would not surprise me at all!
Just like the early 71 cars have the 70-carryover rear side marker lamp assemblies with the "shields" or "hoods" protecting the side marker lamp bulb sockets cast into the aluminum lamp housings (My 318 convertible, built 10/70, has them). Later cars have the lamps without the shields.
Bill Rolik
What the hell am I doing up this late?
Re: anal 1971 Cuda 101? [Re: bremotorsports] #28233
10/26/06 10:30 AM
10/26/06 10:30 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's one for you guys. I recently looked at a low mile survivor 71 non billboard Cuda, it had the drivers side inside retainer over sprayed heavily in body color but the passenger side was unpainted. It's possible that the passenger side was replaced but as far as I could see there were no obvious signs that it had been swapped out. Has anyone else seen this?
Re: anal 1971 Cuda 101? [Re: ScottSmith_Harms] #28234
05/01/09 10:14 AM
05/01/09 10:14 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Sorry, off/topic a bit.
Did ALL '71 'Cudas come w/billboards unless they were stripe delete optioned? Or was it an option only?
Re: anal 1971 Cuda 101? [Re: 2fast4yourBrain] #28235
05/01/09 10:24 AM
05/01/09 10:24 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Quarter Panel SPORT Stripe - aka "BILLBOARDS" was a $37.55 OPTION, approximately 1/3 of all 'Cudas received when new.
Hamtramck-Historical
