Re: 727 Hemi Transmission
[Re: 426lloyd]
#2822061
09/17/20 09:19 PM
09/17/20 09:19 PM
Posts: 3,114 Michigan
A727Tflite
Thank you will pass this on to my debater , he says he has one , told him maybe you do , but not from the factory , then he says he has a factory hemi small block , said nope , he said he can prove it , told him I can can prove you don't , and the rant goes on . There was never a need for a factory built “Hemi” small block trans. If he persists ask him for the PK number stamped in the case. As for the the trans he has with 6 clutches, have him send you a picture of the front clutch retainer and top plate/reaction plate. There are modified plates that allow 6 discs. Again, ask him for the PK number on that one too.
[Re: 426lloyd]
#2822088
09/17/20 10:14 PM
09/17/20 10:14 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
The Hemi torqueflites had and extra clutch and steel in the 2nd gear clutch drum which was also wider than the stock 727. The 2nd gear kick down band was extra wide too.
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
[Re: 6T9Hemi]
#2822105
09/17/20 11:04 PM
09/17/20 11:04 PM
A727Tflite
The Hemi torqueflites had and extra clutch and steel in the 2nd gear clutch drum which was also wider than the stock 727. The 2nd gear kick down band was extra wide too. Correct, we already knew that. The Hemi/Sixpack had 5 front clutch discs - not 6.
[Re: 426lloyd]
#2822164
09/18/20 08:46 AM
09/18/20 08:46 AM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
Thank you will pass this on to my debater , he says he has one , told him maybe you do , but not from the factory , then he says he has a factory hemi small block , said nope , he said he can prove it , told him I can can prove you don't , and the rant goes on . He says he has a factory hemi small block engine? If so it reminds me of the old saying, never argue with a idiot, he'll drag you down to his level than beat you with experience and from a distance no one can tell the difference.
[Re: 426lloyd]
#2822238
09/18/20 12:35 PM
09/18/20 12:35 PM
Posts: 26,044 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Using a liberal interpretation of "factory", there was a SB 727 with Hemi internals offered from the old Direct Connection P/N P3878010. It was a race unit with a RMVB.
