A arm #2821658
09/16/20 06:31 PM
09/16/20 06:31 PM
florida dade
cesar perez Offline OP
florida dade
What weight savings switching to.A arm front suspension in a a body car
Re: A arm [Re: cesar perez] #2821688
09/16/20 07:50 PM
09/16/20 07:50 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I built a tube chassis Abody car for drag race only and regret not going to a strut front end for definite weight savings.Aftermarket Aarm suspension with coilovers would probably offer more tunability than T-bars but not a big weight saver for the bucks.Member DVW runs a Bbody drag car that I believe still has a lightened T-bar front suspension and he is knocking on the 8sec door!Struts are the way to go for the real weight savings.Regret that Ididn't go that way. Bill
Re: A arm [Re: lancer493] #2821727
09/16/20 09:58 PM
09/16/20 09:58 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When I bought my AJE he claimed 125# weight savings. Unfortunately, the fine print is you only save that much when removing power steering, power brakes, and factory brakes. It's closer to 40# or so when you have manual steering snd brakes.
Re: A arm [Re: slantzilla] #2821798
09/17/20 07:30 AM
09/17/20 07:30 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
All the stock suspension excluding brakes only weigh 123 lbs. so there is no way to loose a 125 lbs. the tubular uppers are heavier than the stamped stock ones . the lowers are less than a half a lbs. lighter. the k frame is 2.5 lbs lighter.Then that's almost nothing if you have a stock k frame that has been cut for oil pan. I have made a list of what every part weighs. So I don't get where guys say they lost a 125 lbs.
JAKES AUTOMOTIVE
Re: A arm [Re: JAKE68] #2822183
09/18/20 10:00 AM
09/18/20 10:00 AM
PA
moparacer Offline
moparacer  Offline
PA
No way 125 lbs.
I put one of Tory Shellehamers tube frame setups on my car over the winter and I think Tory told me 60 lbs or so. And I think his is as light as you can possibly get.
I went to an aluminum firewall, dash, tunnel, and lexan windows, cut off everything I didn't need up front, and with his suspension cut 150lbs.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
