Re: Fuel pressure before the regulator
[Re: fast68plymouth]
#2822697
09/19/20 07:07 PM
09/19/20 07:07 PM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
If you look at the regulator on the inner fender, you will see another regulator which the fuel just runs thru. I tapped into the fitting there for my inside gauge thinking it would read pump pressure. Didn't see a problem doing it this way as if i ever go back to my Dominator, the regular is right there. I get it, with a return it will only have what ever pressure i set at carb.
[Re: Dragula]
#2823368
09/21/20 05:00 PM
09/21/20 05:00 PM
mopar dave
Mt Morris Michigan
Thinking it’s time to retire my old SX fuel pump. Looking at a Magnafuel 275 and a 300.
[Re: mopar dave]
#2823393
09/21/20 06:24 PM
09/21/20 06:24 PM
Thumperdart
State of confusion
Been running the Magna fuel 300 for many years and even on 1 plus hour drives and it's a great pump and no return needed, it returns directly back to the cell .......
[Re: AndyF]
#2823539
09/22/20 09:12 AM
09/22/20 09:12 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
I'd remove the regulator on the inner fender. Replace it with a union fitting and put the regulator back in a box on the shelf so if you go back to the Dominator you have it. Running two regulators in series like that is asking for problems. If you need a place to tap in for fuel pressure then use a union fitting with a 1/8 NPT port on the size. I run 20 psi to my fuel log.
[Re: mopar dave]
#2823694
09/22/20 04:21 PM
09/22/20 04:21 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
I read a bunch on reviews on the Magnafuel 275 that were not positive. Many leaking pumps or locked up. Mine locked up at the drag strip after about three years of street/strip use. I completely rebuilt it and after about six months it started leaking again so now it sits on the shelf. I'm not sure I'll ever use Magnafuel again. From what I understand the pumps are made here and the motors are made overseas.
[Re: justinp61]
#2823702
09/22/20 04:49 PM
09/22/20 04:49 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
I have a Magnafuel 275 and have had issues with the seal on the shaft of the motor leaking. I had it mounted laying down so that may have an effect on it, although Magnafuels tech told me it could be mounted in any position. I got tired of replacing seals and took it off and put my old Holley Billet 150 back on. Yep, i have often wondered why people spend all that money on those, which i always hear tales of woe about. When a Holley black will easily satisfy the needs of 95% of the N/A street strip or bracket cars on the board, and are way cheaper and very, very rarely fail. I know they are plenty capable of supporting a high 9 sec 3350 pound car, using a T brake. Most foolish thing i have done( among many..lol) was getting talked into “ upgrading” my fuel system. I did, and didnt see a thousandth difference, except in my wallet.
