Re: Fuel pressure before the regulator
[Re: fast68plymouth]
#2822697
09/19/20 07:07 PM
09/19/20 07:07 PM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
If you look at the regulator on the inner fender, you will see another regulator which the fuel just runs thru. I tapped into the fitting there for my inside gauge thinking it would read pump pressure. Didn't see a problem doing it this way as if i ever go back to my Dominator, the regular is right there. I get it, with a return it will only have what ever pressure i set at carb.
[Re: Dragula]
#2823368
09/21/20 05:00 PM
09/21/20 05:00 PM
mopar dave
Mt Morris Michigan
Thinking it’s time to retire my old SX fuel pump. Looking at a Magnafuel 275 and a 300.
[Re: mopar dave]
#2823393
09/21/20 06:24 PM
09/21/20 06:24 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Been running the Magna fuel 300 for many years and even on 1 plus hour drives and it's a great pump and no return needed, it returns directly back to the cell .......
[Re: AndyF]
#2823539
09/22/20 09:12 AM
09/22/20 09:12 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I'd remove the regulator on the inner fender. Replace it with a union fitting and put the regulator back in a box on the shelf so if you go back to the Dominator you have it. Running two regulators in series like that is asking for problems. If you need a place to tap in for fuel pressure then use a union fitting with a 1/8 NPT port on the size. I run 20 psi to my fuel log.
[Re: mopar dave]
#2823694
09/22/20 04:21 PM
09/22/20 04:21 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I read a bunch on reviews on the Magnafuel 275 that were not positive. Many leaking pumps or locked up. Mine locked up at the drag strip after about three years of street/strip use. I completely rebuilt it and after about six months it started leaking again so now it sits on the shelf. I'm not sure I'll ever use Magnafuel again. From what I understand the pumps are made here and the motors are made overseas.
[Re: justinp61]
#2823702
09/22/20 04:49 PM
09/22/20 04:49 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I have a Magnafuel 275 and have had issues with the seal on the shaft of the motor leaking. I had it mounted laying down so that may have an effect on it, although Magnafuels tech told me it could be mounted in any position. I got tired of replacing seals and took it off and put my old Holley Billet 150 back on. Yep, i have often wondered why people spend all that money on those, which i always hear tales of woe about. When a Holley black will easily satisfy the needs of 95% of the N/A street strip or bracket cars on the board, and are way cheaper and very, very rarely fail. I know they are plenty capable of supporting a high 9 sec 3350 pound car, using a T brake. Most foolish thing i have done( among many..lol) was getting talked into “ upgrading” my fuel system. I did, and didnt see a thousandth difference, except in my wallet.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
