Re: sorry in advance tire wheel combo question
[Re: Mopar Mitch]
#2824154
09/23/20 03:19 PM
09/23/20 03:19 PM
Posts: 31,029 Oregon
AndyF
Actually, to keep the wheel/tire centered within the factory wheel well and, most importantly the on-center track width, the correct BS for a 9" rim is 5", then a 10" rim is 10.5". Zero offset basically? I've always thought Mopar cars worked best with 1/2 inch of offset. So 5.5" BS on a 9 inch rim and 6.0" BS on a 10 inch rim. I usually start with 1/2 inch of offset on any Mopar I work on and then go from there. I keep a stack of spacers on the shelf so I can move the rim back out 0.125 or 0.250 to get things perfect.
[Re: Kern Dog]
#2826156
09/28/20 05:01 PM
09/28/20 05:01 PM
Posts: 4,672 Wichita
GY3
Wichita
IMO... for any B-body, Frankenduster's wheel tire setup is really good.... tire/rims wide enough and tall enough... correct rim backspacing is the key to make them fit properly. Thank you, Sir ! The outer wheel tubs in these cars is a bummer though. The design makes for clearance problems with a lowered car. I found these pictures online. Someone had forethought while doing quarter panel replacement. Was done here locally by a shop in Newton, KS.
