Non congealing Edelbrock #2821316
09/15/20 10:38 PM
09/15/20 10:38 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Anybody know why I would have a Edelbrock intake( fit horribly by the way) on my 360
But few gallons of gasket sealer LOL and a bunch of Hail Marys it didn't leak
Slap on a brand new Edelbrock 600 CFI carburetor
Then the Edelbrock aftermarket air filter doesn't fit on top of it, why the hell would that be? anybody else have this problem too?
Or recommend spacer
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Non congealing Edelbrock [Re: Caparco] #2821330
09/15/20 11:34 PM
09/15/20 11:34 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
You need Edelbrock 1221 air cleaner to clear an Edelbrock carb with electric choke. If you have the 1207 air cleaner you need a spacer or a banjo fitting for manual choke.
The only Carbs I care about are under the hood!
Re: Non congealing Edelbrock [Re: Azzkikrcuda] #2821413
09/16/20 09:26 AM
09/16/20 09:26 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You can use a drop base air cleaner with an electric choke Edelbrock but it can be no more than 3/4" drop. Any more then that and the base will hit the electric choke. I modified a 1" drop base to fit on mine but it was a lot of work and I also had to modify the air filter as well. On my setup, hood clearance is limited and I don't like the look of short air filters.
Re: Non congealing Edelbrock [Re: Azzkikrcuda] #2821784
09/17/20 04:30 AM
09/17/20 04:30 AM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Oh I see!...so I won't need a spacer with it! I guess I had the 1207. Great info thanks
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
