Holley Guru's......Jet storage #2821299
09/15/20 09:48 PM
09/15/20 09:48 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
What do you guys store all your jets in?
I now have two full holley jet cases and then two more plastic snap cases just to carry all my jets and air bleeds. I have 4 or more of every size from #23-#110....
I need somthing that holds all of them preferably.....What the heck is everyone using or am I the only idiot that carries around a big pile of jets?
Re: Holley Guru's......Jet storage [Re: Dragula] #2821320
09/15/20 10:51 PM
09/15/20 10:51 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I would store the ones you won't ever use( probably 75% at least of what you have) and put the others in the Holley jet box To take to the track or have handy at your shop
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Holley Guru's......Jet storage [Re: B3422W5] #2821336
09/15/20 11:55 PM
09/15/20 11:55 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I use this.
Re: Holley Guru's......Jet storage [Re: cudadoug] #2821344
09/16/20 01:00 AM
09/16/20 01:00 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Think Fishing Tackle boxes........
Re: Holley Guru's......Jet storage [Re: cudadoug] #2821366
09/16/20 05:43 AM
09/16/20 05:43 AM
Dragula Offline OP
Dragula  Offline OP
Originally Posted by cudadoug
I use this.
I have three of those full!
Re: Holley Guru's......Jet storage [Re: Dragula] #2821384
09/16/20 08:03 AM
09/16/20 08:03 AM
NC
440Jim Offline
440Jim  Offline
NC
The plastic compartments of the Holley jet case will hold much more than 4 of each jet size. So one of those will hold all the jets.
The air bleeds need another case or plastic bin.
I suggest putting the jets near your current jet size in one of those threaded aluminum plates and only take that to the track (with one air bleed size change too). Put the cases in your garage for when you need them.
Holly 122-220 link $18.
Re: Holley Guru's......Jet storage [Re: cudadoug] #2821386
09/16/20 08:09 AM
09/16/20 08:09 AM
an8sec70cuda Offline
I use this.
Same here.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Holley Guru's......Jet storage [Re: an8sec70cuda] #2821397
09/16/20 08:36 AM
09/16/20 08:36 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use this.
Same here.
X3
Re: Holley Guru's......Jet storage [Re: justinp61] #2821404
09/16/20 09:08 AM
09/16/20 09:08 AM
The Great State of PA
tabletop390 Offline
tabletop390  Offline
https://csr-performance.com/shop/product.da/csr300-holley-gas-jet-kit for the trailer. Otherwise it's Harbor Freight boxes and a Sharpie at home.
Re: Holley Guru's......Jet storage [Re: tabletop390] #2821408
09/16/20 09:20 AM
09/16/20 09:20 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Why not a small Plano plastic tackle box with dividers?
Re: Holley Guru's......Jet storage [Re: sasquatch] #2821448
09/16/20 10:27 AM
09/16/20 10:27 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
That's what I use mostly. Got two of them with the jets I use most, along with many of the small pieces that are needed or ones that get dropped. Still have the big Holley box, but I use the divided fishing tackle box much more often. Think they cost only a couple of bucks each. They were leftover display pieces.
Re: Holley Guru's......Jet storage [Re: sasquatch] #2821453
09/16/20 10:33 AM
09/16/20 10:33 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
What I use. Gaskets, small parts, specific tools, jet boards, All in one place.
Re: Holley Guru's......Jet storage [Re: CMcAllister] #2821460
09/16/20 10:56 AM
09/16/20 10:56 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use the Holley jet boxes and their bleed boxes. For the larger stuff I use another compartmented plastic container that I label with a label maker whats in each compartment. Mine go up to .172" pin size for jets and bleeds from .023-.080"
Re: Holley Guru's......Jet storage [Re: 440Jim] #2821496
09/16/20 12:07 PM
09/16/20 12:07 PM
Dragula Offline OP
Dragula  Offline OP
And what about all the Air Bleeds? I tend to race at least 3 different cars, and they all have their own "range" of jets. So I take everything as I do not want to be missing somthing I need. So I am kinda looking for a solution that has more compartments than the Holley jet kit.
Re: Holley Guru's......Jet storage [Re: Dragula] #2821501
09/16/20 12:16 PM
09/16/20 12:16 PM
AndyF Offline
AndyF  Offline
Use one box per car with only the range of jets that you need for that car in each box. Either that or step up to a more serious storage solution which has enough space for everything in one place.
Re: Holley Guru's......Jet storage [Re: cudadoug] #2821505
09/16/20 12:22 PM
09/16/20 12:22 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I must be lazy.
69 GTX 68 Road Runner
Re: Holley Guru's......Jet storage [Re: JERICOGTX] #2821519
09/16/20 12:46 PM
09/16/20 12:46 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by JERICOGTX
I must be lazy.
Twice a year - end of Spring, beginning of Fall. Easy.
Re: Holley Guru's......Jet storage [Re: CMcAllister] #2821523
09/16/20 12:58 PM
09/16/20 12:58 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I must be lazy.
For the purpose of?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Holley Guru's......Jet storage [Re: BloFish] #2821526
09/16/20 01:08 PM
09/16/20 01:08 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I must be lazy.
For the purpose of?
Compensating for air density with the different seasons to maintain consistency.
Re: Holley Guru's......Jet storage [Re: CMcAllister] #2821531
09/16/20 01:17 PM
09/16/20 01:17 PM
I must be lazy.
iagree Add a little fuel when it cools off in the fall. Take it out when it warms back up. Never seen a ton of difference either way really, as long as the motor is happy.
CHIP
