Re: Removing some spray adhesive on vinyl top...
[Re: fatsat]
#2821284
09/15/20 09:11 PM
09/15/20 09:11 PM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
This is what I've used for decades, don't know if it is still in this container or an updated version? Clean several types of reactive adhesives from a variety of substrates quickly and efficiently with the 3M General Purpose Adhesive Cleaner. This cleaner can effectively remove silicone polish, tar, oil, epoxies, tree sap, light paint overspray, bugs, urethane, wax, and other stubborn adhesives from the surface. Containing a blend of many solvents, this adhesive cleaner is specially formulated not to harm properly cured automotive paint, fabrics, or vinyl when used as directed.
This General Purpose Adhesive Cleaner will not cause any damage to dry paints. It does not require wiping the surface with a dry cloth. The 3M General Purpose Adhesive Cleaner is available in two sizes: 1 quart can and 15 oz. aerosol.
Key Features of the 3M General Purpose Adhesive Cleaner: •Specially formulated solvent blend •Quick and easy cleaning •Removes paint overspray, wax, grease, silicone, oil, road tars, bugs, and more •Does not cause harm to thoroughly cured automotive paint, fabrics, and vinyl if used with care and as per the usage instructions
Then there's 3M Specialty Adhesive Remover. 3M Specialty Adhesive Remover eases the removes reactive adhesives from a variety of substrates. Reactive adhesives include adhesives that require a hardener or catalyst in order for the bond to occur. Examples of reactive adhesives include, but are not limited to: epoxies; urethanes and silicones. This adhesive remover is a solvent-based product.•Product removes reactive adhesives from a variety of substrates •Reactive adhesives include adhesives that require a hardener or catalyst in order for the bond to occur •Examples of reactive adhesives include, but are not limited to, epoxies, urethanes and silicones •Specialty adhesive eases removal of stubborn residue •A solvent-based specialty adhesive remover
[Re: GMP440]
#2823080
09/20/20 09:32 PM
09/20/20 09:32 PM
moparpollack
Lil Herman
Lil Herman
85086
Goof Off worked great for me.
