68 B Body wire.. Where does this go?? #2821013
09/15/20 11:12 AM
09/15/20 11:12 AM
Columbus, Ohio
Chally426 Offline OP
Columbus, Ohio
As you can see, this blk wire comes from the fuse box on the heater fuse.. My guess is this goes to the blk wire on the blowing swicth on the dash, should this be an in-line fuse, right off the fuse box? If so, looks like i might be missing the other half that plugs into the switch.
Re: 68 B Body wire.. Where does this go?? [Re: Chally426] #2821015
09/15/20 11:27 AM
09/15/20 11:27 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The connector on the fuse panel has blue insulation on it. That looks like something someone added at some point. It does look like one half of an inline fuse holder.
Re: 68 B Body wire.. Where does this go?? [Re: burdar] #2821017
09/15/20 11:33 AM
09/15/20 11:33 AM
Columbus, Ohio
Columbus, Ohio
Just noticed that.. You may be right.. Any ideals on the black wire on the heater switch, where it would go to... Looks like it may be a hot feed from the fuse box
Re: 68 B Body wire.. Where does this go?? [Re: Chally426] #2821073
09/15/20 01:01 PM
09/15/20 01:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
There is a black wire from the ign sw that powers up the fuse box for the blower, test lights help figure things out.
Re: 68 B Body wire.. Where does this go?? [Re: Chally426] #2821312
09/15/20 10:18 PM
09/15/20 10:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Thats NOT factory
Re: 68 B Body wire.. Where does this go?? [Re: gtx6970] #2821406
09/16/20 09:16 AM
09/16/20 09:16 AM
Columbus, Ohio
Columbus, Ohio
Thanks bill...
I finally figured it out... there was another black wire with a white tracer I found buried behind the fuse block that feeds the heater switch.
