Re: Indy Aluminum Hemi Block issues?
[Re: maximus]
#2820777
09/14/20 08:32 PM
09/14/20 08:32 PM
Posts: 10,038 MN
JERICOGTX
MN
How much power are you planning on making?
69 GTX
68 Road Runner
[Re: maximus]
#2820942
09/15/20 07:59 AM
09/15/20 07:59 AM
Posts: 10,038 MN
JERICOGTX
MN
That block will have no problems with 850hp.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2821097
09/15/20 01:52 PM
09/15/20 01:52 PM
Posts: 4,688 On the parachute mount
n20mstr
IM making around 14-1500 with an Indy Maxx block. Been using it for well over 10 years and its been ok so far. Biggest things to look for, check all oil passages that they are drilled fully. Check crank clearance at the main bul;kheads, mine needed a little massage at the thrust. Other than that check for normal stuff, decks, linehone, etc. The other thing to get used to is the block will grow (valve lash) and the bores move around. But thats really normal aluminum block issues.
the more you ask, the more you will get both answers, It works well.......it sucks....LOL Based on my experience its a good block
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2821146
09/15/20 03:22 PM
09/15/20 03:22 PM
Posts: 5,117 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I agree n20mstr, the block will move around had that with a friends and his crank did rub on a journal from moving around a little or a lot. 850 is a good number to keep things together with a hemi. This Indy motor was well over 1300 hp.
1971 HEMI E BODY REGISTRY
[Re: cuda499]
#2821224
09/15/20 06:42 PM
09/15/20 06:42 PM
Posts: 1,113 Usa
A39Coronet
Usa
Horrible cooling, and horrible oil return. Besides that, great lol Both of these issues can be solved by using an engine builder who's experienced in these blocks. I've seen some very creative solutions to additional cooling and oiling mods that solve these issues permanently.
[Re: maximus]
#2821414
09/16/20 09:26 AM
09/16/20 09:26 AM
n20mstr
I have been building my own engines for 40+ years. Does anyone know what kind of mods are they doing to improve cooling and oiling issues with these blocks? the only oil return mod i have, is both ends of the heads are tapped for oil return lines to the pan.
[Re: cuda499]
#2821446
09/16/20 10:25 AM
09/16/20 10:25 AM
Posts: 10,038 MN
JERICOGTX
MN
Horrible cooling, and horrible oil return. Besides that, great lol First time I've ever heard of poor cooling in these blocks. Care to explain the problem?
69 GTX
68 Road Runner
[Re: cuda499]
#2821561
09/16/20 02:08 PM
09/16/20 02:08 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Horrible cooling, and horrible oil return. Besides that, great lol What oil return? Ain't nothing coming back to that pan. Mine ran out of oil in around 30-45 seconds. Everybody says, oh you have to have an experienced builder to build it. Well why is that? Why can't Indy just make a block that the oil drains back like it's supposed to? Like every other block ever made in the world. It's not like them doing it their way is making it a better block. Good to see the previous owners of Indy gone.
2011 Drag Pak Challenger
[Re: maximus]
#2821569
09/16/20 02:29 PM
09/16/20 02:29 PM
Posts: 2,926 A shed in England
Tig
A shed in England
I have been building my own engines for 40+ years. Does anyone know what kind of mods are they doing to improve cooling and oiling issues with these blocks? I've seen extra holes drilled in the cam galley for oil return, I was unaware of cooling issues, it isn't a problem on ours.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: maximus]
#2821578
09/16/20 02:48 PM
09/16/20 02:48 PM
rickseeman
Stuttgart, Arkansas
I have been building my own engines for 40+ years. Does anyone know what kind of mods are they doing to improve cooling and oiling issues with these blocks? I looked for some photos of the oiling mods to help you out but I couldn't find any. I probably can't remember them all but I'll try. Big thanks to Todd Marsh and Ray Barton for helping me through that fiasco. First of all, all four of the holes in the block that drain the corners of the heads, were undersize from stock. So I had to order an extra-length drill bit of the proper size and drill them out. Next, there is no oil drain in the lifter valley, so I drilled holes down the middle of the lifter valley, the size and spacing that Todd and Ray told me. Then there is no escape for the oil to the front cover, so I used a hole saw and cut a 1" hole there with the bottom of the hole being flush with the lifter valley so it could drain there. I hope that was all of it. I didn't notice a cooling problem in my very limited driving at the track.
[Re: rickseeman]
#2821604
09/16/20 03:37 PM
09/16/20 03:37 PM
n20mstr
???? OIL returning over the rotating assy cost you power. LOL External drains in the ends of the heads to the pan and its all good...LOL
[Re: n20mstr]
#2821782
09/17/20 03:47 AM
09/17/20 03:47 AM
Tig
A shed in England
???? OIL returning over the rotating assy cost you power. LOL External drains in the ends of the heads to the pan and its all good...LOL Very true but we didn't option lifter oiling so we need some drain back / splash for lube. Also I'm guessing with spray bars and a good scraper / windage tray HP loss is minimized.
[Re: Tig]
#2821790
09/17/20 06:10 AM
09/17/20 06:10 AM
Posts: 4,647 aotearoa
rebel
aotearoa
I have the low deck wedge version of this block. Never had a cooling problem but I did flare out the return holes in the front of the block, (i have reverse flow cooling), As for oil return I opened the holes up in the valley & chamfered them & had no issues with the wet sump. Now I have a dry sump set up, I have a pickup at the back of the valley & to date, haven't experianced any problems. I'm no pro engine builder, I'm just armed with a dremel & did what I thought was necessary. Had my block for over 10 years now, running in the mid 800hp range. I would buy another block no problem.
[Re: JERICOGTX]
#2822346
09/18/20 05:33 PM
09/18/20 05:33 PM
Posts: 154 Canada
cuda499
Canada
By pour cooling, i mean in any car ive ran them, street or strip, they dont stay cold. One street car weight from barley being able to hold it down to 210, to needing a thermostat to stay at 180 with keith black block.... same car, same rads, same fan.
Yes the oil problem can be fixed, but i expected a better product.
Out of everyone commenting, who has bought one of these blocks, built a motor and ran it on the street ...... asking for a friend
Now with that being said, they are under new ownership and they have been making positive changes!
[Re: maximus]
#2822873
09/20/20 11:30 AM
09/20/20 11:30 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My street car has an all aluminum Indy 528 Hemi, I bought the car 85% complete so I have no idea what oil or cooling mods were done to it but I drive it every sunny day. It has a solid roller cam and electric water pump and electric fans. 180 degrees all day long even in traffic.
