Page 3 of 3 1 2 3
Re: Dakota not dead? A followup......... [Re: I_bleed_MOPAR] #2820380
09/13/20 08:23 PM
09/13/20 08:23 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
Geez, been over a month already.......... frowwn
BUT, its not like I'm working on it everyday. blush At this point, I've got about 7 hours into it.
I didn't buy the shrinking disc (yet) but I did buy the finest body working tool set Harbor Freight has to offer (re: the only one). I'm REAL close now. I'm not expecting perfection, but I want to use as little bondo as possible. The way it sits now, I should be able to get the window back in, but before I do that, I want to try to minimize the high and low spots on the roof. I may just try to slowly work with heating/cooling the areas.
This:
To this:
It's not as rough as it looks, my sanding didn't get off all five layers of paint. I made the window plug to not only close the back window, but to monitor the curve of the opening as I work the roof. I know if I used the actual glass I'd either drop it, or drop something on it.
Hopefully one more weekend.
John
Re: Dakota not dead? A followup......... [Re: SattyNoCar] #2820391
09/13/20 08:36 PM
09/13/20 08:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Fwiw shrinking discs only take out high spots if you do end up buying one.
Be careful with heating anything. Heat is good, but uncontrolled heat like from a torch can make things way worse. A hair dryer or heat gun likely won't get the metal hot enough to do anything you want it to do.
Re: Dakota not dead? A followup......... [Re: Neil] #2822761
09/19/20 10:02 PM
09/19/20 10:02 PM
I carefully used some heat today trying to get out a couple of oil can spots and ended up chasing one all over the back of the roof. Its still there but not as bad as it was.
Lacking a real cut off wheel, I bought some cutting discs for my Dremel to cut the inner structure. That was a waste of time and money......"Ziii *SNAP*Ziiiii*SNAP" flame Honestly, I was worried that with a real cutter, I'd end up going thru the outer roof too, so I did the best I could with it in place.
Doesn't look too bad out in the sun......
But, get it inside under a shop light.......... eek
I've got it to where I can put the window back in, so I may do final shaping with bondo
John
Re: Dakota not dead? A followup......... [Re: SattyNoCar] #2822765
09/19/20 10:16 PM
09/19/20 10:16 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I bought larger thicker wheels for my Dremel at Carlisle some years ago - they work great on sheet metal. Just have to let the dremel cool down now and then
Ride eternal, shiny and chrome
Re: Dakota not dead? A followup......... [Re: DirectSubjection] #2822769
09/19/20 10:27 PM
09/19/20 10:27 PM
I wasn't aware there were thicker discs available. I'll have to look online.
beer
John
Re: Dakota not dead? A followup......... [Re: SattyNoCar] #2822808
09/20/20 07:25 AM
09/20/20 07:25 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
These wheels are fiber-reinforced. Much more durable than the plain ones, but still not what you'd call heavy-duty.
Re: Dakota not dead? A followup......... [Re: BSharp] #2822812
09/20/20 07:42 AM
09/20/20 07:42 AM
Hmmmm....if that's the only difference, then that's what I was using. They didn't seem noticeably thicker than the regular ones.The disc wasn't shattering, it was breaking around the mounting point. The mounting screw isn't long enough to use washers to reinforce the disc.
Wonder if I have the wrong bit? work
John
Re: Dakota not dead? A followup......... [Re: SattyNoCar] #2822953
09/20/20 03:39 PM
09/20/20 03:39 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Lookin' good, John. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Dakota not dead? A followup......... [Re: I_bleed_MOPAR] #2822968
09/20/20 04:24 PM
09/20/20 04:24 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Yeah, that's coming along nicely!
Facts are stubborn things.
Re: Dakota not dead? A followup......... [Re: larrymopar360] #2823097
09/20/20 10:17 PM
09/20/20 10:17 PM
Here
Here
I use reinforced 1.5" wheels that are 1/16" thick. They work great, just have to let the wheel do the cutting.
Page 3 of 3 1 2 3
