Removing X pipe #2820354
09/13/20 07:31 PM
09/13/20 07:31 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I removed my headers to install exhaust manifolds. I was able to get the collector reducers out on the ends of the X pipe. I now need to remove the X pipe to be able to pull my 4 speed but the X pipe is NOT budging from the mufflers. Any tips? I thought about cutting a few inches in front of the mufflers and using a stainless band clamp to reconnect.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Removing X pipe [Re: 71TA] #2820562
09/14/20 11:53 AM
09/14/20 11:53 AM
moparx Offline
moparx  Offline
that sounds like a reasonable solution.
those band clamps are made in several configurations, but i haven't had a chance to try any.
however, i do plan to use them when i build the exhaust for my charger.
hopefully, others will chime in with their experience.
beer
Re: Removing X pipe [Re: moparx] #2820564
09/14/20 11:59 AM
09/14/20 11:59 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
You might consider taking your whole X pipe setup and flange each end, one end that bolts to the collectors and the other ends to you pipes before the mufflers. Mines a 3.5 inch setup and when I need to drop trans its a 15 minute job to drop the whole big X and ive used the same copper gaskets for years.
This may only be practical if you drop the trans alot. But it is nice and looks better then a bunch of clamps imo.
STOP POTATO HATE!
Re: Removing X pipe [Re: Mr PotatoHead] #2820577
09/14/20 12:40 PM
09/14/20 12:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I use the band clamps and have had great luck with them staying tight and holding the exhaust in place with no leaks.
Re: Removing X pipe [Re: stumpy] #2821114
09/15/20 02:27 PM
09/15/20 02:27 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Great info guys. I'll probably just go that route.
Re: Removing X pipe [Re: 71TA] #2821121
09/15/20 02:41 PM
09/15/20 02:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Heat the muffler end up until it's red and tap it with a hammer to smooth out the crimps from the old clamps. Then spray down the connection with penetrating oil.
Re: Removing X pipe [Re: burdar] #2821222
09/15/20 06:39 PM
09/15/20 06:39 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
X2
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
