69 Charger Water Temperature Gauge Reading High #2818773
09/08/20 10:38 PM
09/08/20 10:38 PM
San Jose, CA
Blue69Charger Offline OP
San Jose, CA
The water temperature gauge on my 69 charger is pegging to the maximum at warm idle. I just put in a new thermostat (180°F) and coolant and it is still reading high. I left the radiator cap off and watched the fluid in the tank from a cold start. The thermostat does not appear to open until the temperature gauge is pegged to the right. I checked the resistance from the temperature sending unit to the battery and the ground strap on the firewall at idle. I'm measuring ~23.5 ohms while the temperature gauge is pegged. The oil pressure gauge also appears to be pegged to the right, but the gas gauge is working ok. I checked the resistance from the battery to the engine, and from the battery to the firewall and got less than an ohm of resistance. I unplugged the bulkhead connector from the firewall and measured the resistance from the temperature sending unit plug to its pin on the firewall harness connector and got less than an ohm. The engine does not appear to be overheating. It does not leak out the radiator's overflow tube. What should I check next? Could the gas gauge be working if the dash's 5v voltage regulator was going out?
Re: 69 Charger Water Temperature Gauge Reading High [Re: Blue69Charger] #2818833
09/09/20 09:05 AM
09/09/20 09:05 AM
N
NITROUSN Offline
NITROUSN  Offline
N
All 3 gauges are dependent on the 5 volt feed from the limiter. Two simple tests would to verify your oil pressure with a mechanical gauge and a pyrometer on the coolant or a mechanical gauge. I have the tester for the gauges. I can measure the readings and you could use resistors to duplicate my testers E-1/2-F values.
Re: 69 Charger Water Temperature Gauge Reading High [Re: NITROUSN] #2818856
09/09/20 09:44 AM
09/09/20 09:44 AM
Andrewh Offline
Andrewh  Offline
the gas gauge reading "correct' could just be low on gas.
I would run a test on the VR first. see if it is pulsing with a test light or reading 5 volts with the meter.
The ohms actually are about what I would expect for a pegged gauge, so it may just be the sensor bad. but I would still test the vr first since it is more than 1 gauge.
Re: 69 Charger Water Temperature Gauge Reading High [Re: Andrewh] #2818955
09/09/20 01:04 PM
09/09/20 01:04 PM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
23.5 ohms at the sensor should be at or just left of center on the temperature gauge. For a pegged gauge I would expect at or near 10 ohms at the sensor.
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: 69 Charger Water Temperature Gauge Reading High [Re: KWF340] #2819057
09/09/20 06:59 PM
09/09/20 06:59 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Sounds like a pinched wire to me
Re: 69 Charger Water Temperature Gauge Reading High [Re: Sniper] #2819936
09/12/20 11:20 AM
09/12/20 11:20 AM
San Jose, CA
San Jose, CA
Thanks guys. I just bought a solid state instrument voltage regulator from real time engineering. I'll give it a try.
Re: 69 Charger Water Temperature Gauge Reading High [Re: Blue69Charger] #2819959
09/12/20 12:18 PM
09/12/20 12:18 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If in fact the fuel gauge is reading correctly the replacing of the limiter will not help. As said a simple voltage reading at any gauge input would verify if you have the correct 5 volts.
Re: 69 Charger Water Temperature Gauge Reading High [Re: Blue69Charger] #2820144
09/13/20 07:26 AM
09/13/20 07:26 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
My over the counter stat didn't open until 195...so upon a suggestion I bought a milodon high flow 180 stat and it opens right on the money. (they are pricey but I feel worth the money) I also drilled a 1/8 hole through it.
Re: 69 Charger Water Temperature Gauge Reading High [Re: NITROUSN] #2820164
09/13/20 09:32 AM
09/13/20 09:32 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
If you have a solid state replacement IVR of some sort you can read 5 volts (or whatever the exact voltage output seems to be). If you have the original electromechanical model, it gives a pulsing 12 volt output that averages about 5 volts over time. But you cannot read 5 volts.
Re: 69 Charger Water Temperature Gauge Reading High [Re: 6PakBee] #2820349
09/13/20 07:09 PM
09/13/20 07:09 PM
San Jose, CA
San Jose, CA
I put in the new voltage regulator. Now I think my gauges are reading low. My temperature gauge reads ~170 degrees Fahrenheit when running. It does go up to 180 degrees when the thermostat opens up, but then holds 170 steady. Oil pressure looks a little low. Gas gauge is a little weird. I put gas in the tank until I saw fuel in the filler neck and it read about 3/4 to 7/8 full. It did go up to full when I parked downhill, so maybe the filler neck was still draining into the tank or the float needs adjustment.
Is it possible for the temperature gauge to read lower than the stat temperature? I just installed a 180 degree high flow Edelbrock thermostat and new coolant. The radiator is huge, it was the thickest Griffin 26" radiator they sold ten years ago. I didn't have much clearance with that radiator so I put a Flexalite fan in. I think I might be picking up extra resistance from the bulkhead connector, which is causing the temp gauge to read low. I don't remember if I installed pipe tape on the temperature sensor. That could be effecting the reading too.
Re: 69 Charger Water Temperature Gauge Reading High [Re: Blue69Charger] #2820356
09/13/20 07:50 PM
09/13/20 07:50 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The factory gauge isn't all that precise or accurate.
Re: 69 Charger Water Temperature Gauge Reading High [Re: Sniper] #2820376
09/13/20 08:18 PM
09/13/20 08:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
they can be if calibrated. A royal PITA frown BTDT beer
Re: 69 Charger Water Temperature Gauge Reading High [Re: TJP] #2820411
09/13/20 09:20 PM
09/13/20 09:20 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No indication the OP did or had that done though.
Re: 69 Charger Water Temperature Gauge Reading High [Re: Sniper] #2820784
09/14/20 08:43 PM
09/14/20 08:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I didn't say he did or didn't whistling
You made a statement that they are not that precise or accurate, I made a statement that said they can be if calibrated. beer
Re: 69 Charger Water Temperature Gauge Reading High [Re: TJP] #2823441
09/21/20 08:46 PM
09/21/20 08:46 PM
San Jose, CA
San Jose, CA
I've never calibrated the gauges. Thanks, I'll look into that.
