Page 2 of 3 1 2 3
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2819524
09/10/20 10:50 PM
09/10/20 10:50 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
The biggest limitation of the slant is that it's only 225 ci. No replacement for displacement.
IIRC the stock stroke is 4.125"? So it doesn't sound like you could stroke it a lot (even if such parts were available)...
I agree that a turbo would work well and the plumbing is simpler with intake and exhaust on the same side of the head.
"Speed costs money, son. How fast do you want to go?" work
Re: Lets talk about the leaning tower of power! [Re: DrCharles] #2819576
09/11/20 06:30 AM
09/11/20 06:30 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I would enjoy the Slant for what it is. Reliable simple but not powerful engine. Id clean it up nice and paint it- replace any and all seals and gaskets that can be easily replaced. You have an engine with 1 head gasket as opposed to 2, an engine whos intake manifold does not have coolant going thru it as well as its just an easy to work on and get at everything engine. Any new driver has none of those traits. The Slant 6 is like the early 70s Honda 4 stroke mini and motorcycle engines- the 70-125-250cc engines. By not making alot of power the internal stresses were low contributing to a long running non fussy engine.
Keep old mopars alive.
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2819614
09/11/20 09:54 AM
09/11/20 09:54 AM
GMP440 Offline
GMP440  Offline
Here is a Hot Rod Magazine article on a Slant Six build. This shows what was used and done to get an extra 77 horsepower. Just trying to show that it won't be cheap to get any decent horsepower front a slant six.
https://www.hotrod.com/articles/slant-sickness-add-77-hp-mopar-slant-six/
Lot of good advice given on this thread. From dropping in a v8 to just cleaning up and leaving the slant six the way it is.
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2819657
09/11/20 12:24 PM
09/11/20 12:24 PM
Buy a used 440 with tranny and go enjoy it up twocents work
Re: Lets talk about the leaning tower of power! [Re: Cab_Burge] #2819726
09/11/20 04:04 PM
09/11/20 04:04 PM
GMP440 Offline
GMP440  Offline
[align:right][/align]
Should be plenty of those around since owners are now wanting to drop in gen III hemi's.
Re: Lets talk about the leaning tower of power! [Re: GMP440] #2819732
09/11/20 04:22 PM
09/11/20 04:22 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
FWIW, I've driven or owned several Slants, and the 170/stick in a '60 Valiant was actually kinda peppy.
Seemed happier @ 70-75 MPH than the long-stroke 225s.
That Valiant weighed a lot less than the '70s Dart & Duster 225s I had, obviously a factor accelerating.
Being such a long stroke, on a 225 I would think enhancing low- & mid-range torque would be the best approach.
But even a stock 318 in the same chassis was better IMO, with no real MPG penalty.
Re: Lets talk about the leaning tower of power! [Re: topside] #2819737
09/11/20 04:46 PM
09/11/20 04:46 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Its reassuring though to have an engine thats quiet, easy to work on, reliable and gets great mileage. Get in that thing and drive worry free. Have the carb set up spot on for instant starts in any weather condition. Save the V8- whatever the size for another project.
Re: Lets talk about the leaning tower of power! [Re: 2boltmain] #2819782
09/11/20 07:13 PM
09/11/20 07:13 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you can find a BBD that doesn't have the throttle shaft completely worn out, it is a good upgrade on a factory 2bbl intake.
Re: Lets talk about the leaning tower of power! [Re: slantzilla] #2819892
09/12/20 07:51 AM
09/12/20 07:51 AM
Slantytown
DUFFMAN Offline OP
Ask And Ye Shall Receive
DUFFMAN  Offline OP
Slantytown
I have a really nice BBD that looks like it's practically brand new. The problem is the intake I picked up is cracked, which I later found out is a common problem. So now I need to hunt for a cast iron intake.
No longer taking $h!t from anyone!
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2819916
09/12/20 09:41 AM
09/12/20 09:41 AM
Is the cracked intake aluminum?
If so have it welded by a decent shop twocents weld up
Re: Lets talk about the leaning tower of power! [Re: Cab_Burge] #2820101
09/12/20 10:10 PM
09/12/20 10:10 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Is it the 2 piece welded together intake? Many of those have been fixed with JB Weld and a couple coats of epoxy paint.
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2820189
09/13/20 11:31 AM
09/13/20 11:31 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Master, again and still
Re: Lets talk about the leaning tower of power! [Re: slantzilla] #2820365
09/13/20 07:59 PM
09/13/20 07:59 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
Yes. It's cracked up pretty bad around the EGR right below the carburetor. Even if I could patch it up with JB weld I already made the mistake of separating the 2 manifolds so I broke off 2 of the 3 bolts that hold the 2 together.
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2820370
09/13/20 08:11 PM
09/13/20 08:11 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
bump the timing up, they like it and so will you
Re: Lets talk about the leaning tower of power! [Re: 500ciDuster] #2820412
09/13/20 09:25 PM
09/13/20 09:25 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
I set the base timing at 5° BTC.
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2820731
09/14/20 06:48 PM
09/14/20 06:48 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Recurving the distributor works well. I have one with the advance slots welded about 1/2 way up. I run 15-18 initial and 32 total. There was a huge thread about curves for street cars on www.slantsix.org .
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2820786
09/14/20 08:48 PM
09/14/20 08:48 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
On another forum a member toyed with putting another block in line, ie a slant 12? Guess that would make the car a mid engine powered car?
I think he finally came to his senses.
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2821997
09/17/20 05:41 PM
09/17/20 05:41 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
Why buy a /6 B body if you are looking for performance?
Re: Lets talk about the leaning tower of power! [Re: 1970GTX] #2822029
09/17/20 07:35 PM
09/17/20 07:35 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
I actually bought the car for parts, but it's too solid and too "odd" to part it out. I'm not looking to make it into a drag car I just want to get the most I can out of it without doing anything drastic.
Re: Lets talk about the leaning tower of power! [Re: DUFFMAN] #2822247
09/18/20 12:58 PM
09/18/20 12:58 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
So I've been able to pool up almost all the parts for the 2 barrel swap. The only problem now is the manifolds. Do I find someone to repair what I have? Or do I look for something different? My concern is that the 2 piece aluminum intake will crack again, even if I do have it welded. Maybe I should find a cast iron intake?
Page 2 of 3 1 2 3
