no L turn signal, where to start #2819679
09/11/20 01:13 PM
09/11/20 01:13 PM
RapidRobert Offline OP
1973 dart. the left dash indicator light stays on when I lower the stalk. the brake lights do work. right side is OK. thank you for your time.
Re: no L turn signal, where to start [Re: RapidRobert] #2819680
09/11/20 01:19 PM
09/11/20 01:19 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
You DID check the front bulb too, right? smile
Re: no L turn signal, where to start [Re: DrCharles] #2819688
09/11/20 01:36 PM
09/11/20 01:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Could be a bad flasher. Yes one side could work while the other doesn't.
Re: no L turn signal, where to start [Re: stumpy] #2819752
09/11/20 05:31 PM
09/11/20 05:31 PM
Oh I forgot all about the front bulb blush & stump is there 2 flashers or just one?
Re: no L turn signal, where to start [Re: RapidRobert] #2819758
09/11/20 05:42 PM
09/11/20 05:42 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
One turn signal, one hazard.
Re: no L turn signal, where to start [Re: RapidRobert] #2819759
09/11/20 05:44 PM
09/11/20 05:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
2 one for turn and one for emergency. When you have the left signal on what are the left side bulbs doing? even if one side flashes there may be enough difference in résistance that would cause the flasher not to cycle the other side. If all else fails it could be the turn signal switch. If you have a friendly parts store that can get the switch you can just plug it in and test it without tearing the column apart.
Re: no L turn signal, where to start [Re: stumpy] #2819766
09/11/20 06:06 PM
09/11/20 06:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm thinking LF bulb or socket or corroded ground.
I'd start there, then test for signal-power at the TS harness plug, and work backwards.
Re: no L turn signal, where to start [Re: topside] #2819816
09/11/20 08:43 PM
09/11/20 08:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: no L turn signal, where to start [Re: TJP] #2819829
09/11/20 09:16 PM
09/11/20 09:16 PM
thanks guys, good stuff, I'll get on it
Re: no L turn signal, where to start [Re: RapidRobert] #2819876
09/12/20 06:02 AM
09/12/20 06:02 AM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
also check the GROUND for the front bulb.
perception is 90% of reality
Re: no L turn signal, where to start [Re: Mr T2U] #2819908
09/12/20 09:02 AM
09/12/20 09:02 AM
^^^ I'll do that too
Re: no L turn signal, where to start [Re: RapidRobert] #2819950
09/12/20 12:00 PM
09/12/20 12:00 PM
moparx Offline
moparx  Offline
my thoughts were grounds and corroded sockets as well.
beer
Re: no L turn signal, where to start [Re: moparx] #2819957
09/12/20 12:18 PM
09/12/20 12:18 PM
central il.
second 70 Offline
second 70  Offline
central il.
Just had that happen on mine. Rear bulb burnt out.
Re: no L turn signal, where to start [Re: Mr T2U] #2819995
09/12/20 02:37 PM
09/12/20 02:37 PM
Quote
Ding ding ding I do believe we have a winna (more than 1). there's a whole lot of plastic in that housing. thank you!
Re: no L turn signal, where to start [Re: RapidRobert] #2820069
09/12/20 08:25 PM
09/12/20 08:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
