Ignition Wiring Problem I can't seem to figure out
#2819543
09/10/20 11:39 PM
09/10/20 11:39 PM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
This is in my wife's 74 Ramcharger (440/Auto).
I've just finished up swapping in 1 ton axles out of first gen cummins truck and over the last few years I've been working on this truck little by little and it's time to fire it up and drive it out of the garage for the first time in 10 years!
Anyhow, after hooking everything up, when I turn the key forward, to the run position, the coil stars humming. Turning the key to the start position I get no fire and no voltage.
The Ignition 2 Lead is the one that has me really frustrated, it should ONLY have power in the start position and provide power to the coil, instead it's got 8.9V in Run, and no voltage in start.
I've only got one electrical tester, but I think something is backfeeding maybe? I've used two NEW ignition switches and have the exact same results. There are NO modifications to the wiring and no aftermarket anything. I want to make sure everything works 100% before I change anything (planning on ampmeter bypass but that's about it)
I've recently went thru the entire Dash, Forward Light, Rear, and Engine harnesses verifying every single wire for continuity and verified they're in the correct bulkhead position against the 1974 Factory Service Manual. The Dash Harness is out of a 75 Dodge Truck with Factory A/C (all of it's wiring was identical to the FSM), and the Forward Light & Rear Harnesses are out of a 74 W200, and the Engine harness is a NOS M880 harness. Everything in all of the harnesses matched up to the FSM.
I'm hoping someone here has come across a similar issue or perhaps can lead me in the right troubleshooting path.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
Re: Ignition Wiring Problem I can't seem to figure out
[Re: Andrewh]
#2819617
09/11/20 10:10 AM
09/11/20 10:10 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Okay, first things first, is this the ignition setup that you have?
[Re: shanker]
#2819655
09/11/20 12:20 PM
09/11/20 12:20 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I've never heard a coil hum It is talking to you saying something is goofy, I think Is your ECU a 4 pin or 5 pin? What test device are you using? If it is a volt ohm meter what is your battery voltage with nothing turned on and what is it with the key turned on to the run position and then in the start position? You can fix this, it is something, wiring, that is not connected correctly
[Re: shanker]
#2819672
09/11/20 12:59 PM
09/11/20 12:59 PM
Posts: 25,783 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've heard that a bad ECU can cause coil hum/buzz.
[Re: Cab_Burge]
#2819686
09/11/20 01:30 PM
09/11/20 01:30 PM
shanker
Corpus Christi, TX
I've never heard a coil hum It is talking to you saying something is goofy, I think Is your ECU a 4 pin or 5 pin? What test device are you using? If it is a volt ohm meter what is your battery voltage with nothing turned on and what is it with the key turned on to the run position and then in the start position? You can fix this, it is something, wiring, that is not connected correctly When I say Hum, it's trying to constantly fire, If I remove the plug wire from it, a spark show emerges. The ECU is a MP Orange Unit, 4 Pin. I'm using this Ideal tester https://www.idealindustries.ca/products/electrical/electrical-testing/61-746.htmlBattery Voltage is 12.9V at the terminals, which I also get unless I'm on the Bypass Circuit/IGN 2 and it's 8.9V
[Re: shanker]
#2819754
09/11/20 05:35 PM
09/11/20 05:35 PM
RapidRobert
When I say Hum, it's trying to constantly fire, If I remove the plug wire from it, a spark show emerges. would you have another coil that you could borrow?
[Re: RapidRobert]
#2819755
09/11/20 05:41 PM
09/11/20 05:41 PM
shanker
Corpus Christi, TX
When I say Hum, it's trying to constantly fire, If I remove the plug wire from it, a spark show emerges. would you have another coil that you could borrow? I'm going to pull one off another car. (I drove this Ramcharger into my garage 11 years ago though ) Something else I just discovered, when the key is in the "RUN" position, the Fusible Link gets hot FAST...and when I say hot, I don't think they're supposed to get that hot.
[Re: NITROUSN]
#2820112
09/12/20 11:29 PM
09/12/20 11:29 PM
shanker
Corpus Christi, TX
I made some progress today.
The coil wanting to fire fixed itself. That sounds weird, but after bumping the engine over (screw driver across the starter relay terminals), it didn't do that again. Perhaps the distributor was in just the right position that the coil wanted to fire? Is that even possible?
I was able to get the truck running by having the key in run position, jumping the starter relay, and fogging starting fluid into the air cleaner.
I still have NO JOY on the IGN Start or IGN #2 circuits. I'm really thinking I've managed to get two bad ignition switches back to back.
[Re: shanker]
#2820223
09/13/20 01:38 PM
09/13/20 01:38 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Yes, but hard to say it was likely. Coils fire when the electric field inside the coil is charged then de-powered causing it to collapse and the energy released out the coil wire. In short, to fire a coil, you have to turn the voltage on and off, a static distributor SHOULD not do that. However, it is electricity and the ECU could be getting just the right kinda sketchy signal and it freaked. It is the ECU that switches the electricity to the coil on and off. I still have NO JOY on the IGN Start or IGN #2 circuits. I'm really thinking I've managed to get two bad ignition switches back to back. How are you checking for voltage? I have seen people backprobe the connector and miss the wire thinking it was not a getting power. I prefer to use a OHM Meter or Continuity tester to check the switch when unplugged just to be sure. Another option is to stick a safety pin through the middle wire to get a reading from it. Do not do this on wires exposed to elements like under hood or under the car without sealing the wire afterwards. You can also check for voltage at the yellow wire on the starter relay when in the cranking position. Two things can cause a hot fusible link. Excessive current draw or a failing link that is starting to slowly burn away inside. Pretty common on our cars. If you flex the link and the voltage at the fuse block fluctuates, it feels crispy inside or it makes any kind of crunchy noise it is bad. A bad fusible link could cause any number of weird problems including random power loss or coils misfiring when the connection is shotty. They can not be visibly inspected because the insulation is designed to not burn it can look good and be bad.
[Re: IMGTX]
#2820514
09/14/20 09:34 AM
09/14/20 09:34 AM
shanker
Corpus Christi, TX
I found the problem....and made a 12 second video showing what it was...I gotta figure out how to post it...
and yes, two bad BRAND NEW ignition switches in a row, different issues with each.
[Re: TJP]
#2824030
09/23/20 12:18 PM
09/23/20 12:18 PM
shanker
Corpus Christi, TX
I figured out how to upload the video. I posted it as a Product Review to Amazon. https://www.amazon.com/vdp/f516000a882243e0b9ae5a1a6bc1ebc4?ref=dp_vse_rvc_0If you'll notice, the start circuit is engaged not in the start position, but in between Run & Start. The other circuits are sending power at odd ball times too telling me that it's clocked wrong on the inside. The replacement switch does the same thing I opened up a Standard Motor Products switch and an OEM switch, they are designed entirely different but the OEM switch is more simple and has larger contact area's when the different circuits are supposed to engage.
