Wiper help #2819365
09/10/20 03:26 PM
09/10/20 03:26 PM
N.J. north west
1972challenger Offline OP
N.J. north west
It's raining here in the northeast and I'm out driving around and my wipers stopped working. I have an 86 Ram. I look down in the cowl and find that the arm popped off the motor. I got a new bushing from NAPA and struggle to pop in on through the motor hole only to have the whole linkage fall apart.
First question is, how hard is it to get the cowl off? Do I have to pull the windshield or dose in just sit under to rubber?
The NAPA bushing doesn't even hold the motor to the linkage, do the Doorman ones at Autozone work? I also found some OEM mopar ones on Ebay.
Thanks fellows.
Re: Wiper help [Re: 1972challenger] #2819387
09/10/20 04:36 PM
09/10/20 04:36 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
The cowl slips under the rubber windshield gasket and held in place by some phillips head screws above the firewall.
All of the bushings should be the same. I use the Dorman ones. Use a small socket and c-clamp to press the bushing into the arm, then use the c-clamp to press the arm with bushing onto the stud.
Replace ALL of the bushings while you are in there. The others will fail and you will be cussing the truck in the rain. lol
Oh and prepare to give up some blood as the edges of the cowl access areas are sharp.
Re: Wiper help [Re: Hugh Jorgan] #2819394
09/10/20 04:53 PM
09/10/20 04:53 PM
N.J. north west
N.J. north west
Awesome! Thanks! I haven't worked on one of these since the early 90's.
Re: Wiper help [Re: 1972challenger] #2819410
09/10/20 05:24 PM
09/10/20 05:24 PM
Wills Point, Texas
Wills Point, Texas
I always keep a bottle of Rain-X in the truck just in case.
Re: Wiper help [Re: Hugh Jorgan] #2819629
09/11/20 11:04 AM
09/11/20 11:04 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
agree, do them all at the same time. and a touch of grease on the bushings helps them pop back on.
1981 Dodge D150 360 auto
Re: Wiper help [Re: basketcase] #2819917
09/12/20 09:44 AM
09/12/20 09:44 AM
RWG75
RWG75
take wiper arms off, remove cowl, unbolt both wiper pivots, pull the whole drive out, replace the bushings on the bench. Way easier than fighting inside the cowl just pay attention to what connects where. Pivots should have a R and L stamped in them, flip em and the wiper stroke is wrong. Doorman sells a box of 10 for cheap on rockauto.
