Re: E-body Heater Control Valve
[Re: 469runner]
#2820196
09/13/20 12:14 PM
09/13/20 12:14 PM
Posts: 203 Alabama
David1971
Alabama
It is my understanding that 71 - 74 E-bodies (and some 70 models) with AC were fitted with the type H30-111 bakelite heater control valve. The 111 valve was a cable activated "pull to open" valve. That is a type H30-112 valve you have pictured. It has the "pull to close" style lever atop the bakelite valve body. With the 112, your dash mounted control for the heater TEMP would work in reverse. In other words, to increase the temperature you move the control lever to COOL or LOW and to decrease the temperature you move the lever to WARM or HIGH. Am I correct?
David
[Re: 469runner]
#2822597
09/19/20 01:34 PM
09/19/20 01:34 PM
Posts: 10,705 North Dakota
6PakBee
North Dakota
That heat shield is a good idea. I use headers, so probably not cooking it as much as an iron manifold. Those things hold so much heat. Every vehicle is different so I'm not going to try to make a sweeping statement here. On my '65 Sport Fury when I had the stock log manifolds all was good. When I went to headers, the underhood temperature rose so much that after a high speed run the inner fender rubber covers would smoke. Had to paint the headers white to stop that.
[Re: 469runner]
#2822681
09/19/20 06:04 PM
09/19/20 06:04 PM
Posts: 203 Alabama
David1971
Alabama
I think you are correct David. I just found that picture on the web for reference. Really, the only difference I can see between the 111 and the 112 are the arms. Probably could be switched on a unit if need be. But, I do believe the 111 is what the E-body's came with, the pull-to-open. Oh OK, I assumed it was off of your Cuda. I have 111 that is a junker...huge crack on the valve body and the base is badly corroded. However, the arm/lever is perfect. I bought a 112 at a good price so I could swap out the arms. The 111's have gotten pricey. David
