Re: Brake piston compressor [Re: DirectSubjection] #2814203
08/28/20 06:47 AM
08/28/20 06:47 AM
Central Pa
moparjim79 Online content
moparjim79  Online Content
Central Pa
Originally Posted by DirectSubjection
Thats my go to as well
Re: Brake piston compressor [Re: Sunroofcuda] #2814204
08/28/20 06:49 AM
08/28/20 06:49 AM
Central Pa
Central Pa
Originally Posted by Sunroofcuda
Originally Posted by Mr T2U
on compressing regular disc brake pistons i use a big Chanel lock pliers or a "C" clamp vice grips.
i have also just stuck a screwdriver between a brake pad and the rotor and pried the piston in a bit. then removed the caliper and 1 pad on the non piston side. re install caliper, stuck the screwdriver in big gap and press the piston back in..
NOTE when i do all of the above. i loosen the bleeder screw so when i compress the piston in the fluid goes out the bleeder, the piston compresses easily compared to not opening the bleeder and i don't force dirty fluid back into the master cylinder
from what i have READ, i hasn't used this tool. the HF tool works pretty good when pressing in rear disc brake pistons with E brake that's part of the rear caliper..
https://www.harborfreight.com/disc-...html?_br_psugg_q=disc+brake+caliper+tool
I checked out the Harbor Freight kit - not nearly as good of a kit or a deal as this:
Thank you for posting this!
Re: Brake piston compressor [Re: moparjim79] #2814205
08/28/20 07:04 AM
08/28/20 07:04 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've always just used a big C clamp and old brake pad.
Re: Brake piston compressor [Re: DusterKid] #2814219
08/28/20 08:50 AM
08/28/20 08:50 AM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
Typically I have used a big c-clamp but on one of my old VW GTI’s you had to rotate the piston while pushing it back in so I would rent the tool from the dealer when I had to do the brakes on that car. On the VW I can’t recall if it was just the back, or front and back on that car. After owning that car I now always check to verify if I can push the piston straight back in or need to rotate it.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Brake piston compressor [Re: dfsmopars] #2814325
08/28/20 12:16 PM
08/28/20 12:16 PM
Kentucky
dfsmopars Offline OP
Kentucky
I’m thinking with new vehicles you need one tool for the rear and another for the front.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Brake piston compressor [Re: dfsmopars] #2814435
08/28/20 03:57 PM
08/28/20 03:57 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
cars with the emergency brake built into the rear caliper is why the piston needs to be turned in.
most new cars are designed this way so yes you will probably need 2 different tools to compress the pistons on the calipers.
perception is 90% of reality
Re: Brake piston compressor [Re: Mr T2U] #2814550
08/28/20 09:45 PM
08/28/20 09:45 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
welding vise grips!!
my ladder of success is missing some rungs
Re: Brake piston compressor [Re: dfsmopars] #2818852
09/09/20 09:40 AM
09/09/20 09:40 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
