clutch chatter #2818514
09/08/20 12:25 PM
09/08/20 12:25 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
i recently swapped out the 18 spline trans and subbed in a truck od trans on my 70 charger for a cheap od because i drive high speed hiways often.I used an old swap meet clutch and PP I had laying around(23 spline).Anyway since the swap I now have clutch chatter so gonna pull the trans and swap in another clutch...is the chatter being caused solely by the disc or could the pressure plate cause it? I`m assuming its the disc and was planning to just swap in a disc only......
Re: clutch chatter [Re: ogopogo] #2818518
09/08/20 12:32 PM
09/08/20 12:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Odds are its the pressure plate or hot spots in the flywheel will cause it as well
Re: clutch chatter [Re: ogopogo] #2818561
09/08/20 02:05 PM
09/08/20 02:05 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I tried buying just a disc only last year and I couldn't find anyone that sells just the disc. One of the springs were broke in half and the spring retainer ear was broke off too. Everything else looked fine?
I bought a clutch kit and went with a diaphragm style. For the better, I guess, because when you buy a clutch kit you get a matched set and it was reasonable priced. I didn't replace the flywheel and it's been good.
When you get it all back together, You will wish you did the 833od years ago. twocents up
Mo' Farts
Moderated by "tbagger".
