Page 3 of 4 1 2 3 4
Re: 727 parts for street/strip? [Re: TRENDZ] #2811085
08/20/20 02:12 PM
08/20/20 02:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
700 passes on stock input and output shafts. Sons turbo car runs stockers as well. Both have over 850hp
Doug
Re: 727 parts for street/strip? [Re: AndyF] #2811087
08/20/20 02:16 PM
08/20/20 02:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by AndyF
That looks like a classic fatigue failure since it started on an edge and is square across the face. A torsional failure would have more of a spiral shape. So you're probably correct, the shock of the reared end failure probably started a crack and then it just spread over time.
I have 5 or 6 core transmissions to pick parts from so I'm going thru them and grabbing the best parts from each. Most of them have good internals but a couple of them have toasted rear drums. Not sure why, but the rear bands are shot and the drums show signs of being overheated. So I'll probably toss those parts unless they are worth something as cores.
Rear drum is only used in reverse and 1st gear braking. There shouldnt be an issue with those parts unless it was a plow truck.
Doug
Re: 727 parts for street/strip? [Re: AndyF] #2814828
08/29/20 06:07 PM
08/29/20 06:07 PM
AndyF Offline OP
AndyF  Offline OP
I ended up buying a selection of parts from A&A. I got one of the billet steel drums, a 5 pinion steel front planet setup, an aluminum park gear with a governor delete, a lightweight sun shell and an ultimate sprag. I have enough parts on hand to build a second trans so I've decided I'm just going to put all the good parts in a '78 truck case that I had sitting on the shelf and then just swap transmissions. That will give me a spare for the shelf in case I need it down the road. After doing some thread repair I've decided that I'm going to switch to studs rather than bolts for the assembly. I designed a bolt on plug for the speedo but then decided to just use the old 1 49/64 plug trick instead.
Re: 727 parts for street/strip? [Re: AndyF] #2814949
08/29/20 10:44 PM
08/29/20 10:44 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Appears you’re already done, but I think you would have/still can, benefit from the modification that dvw’s son did to his. He used the park hub as an output shaft tone wheel for speed input. Drill and thread the housing. You of all people should be able to put that to good use.
Re: 727 parts for street/strip? [Re: TRENDZ] #2814979
08/30/20 12:17 AM
08/30/20 12:17 AM
AndyF Offline OP
AndyF  Offline OP
I have a driveshaft speed sensor mounted on the pinion yoke.
Re: 727 parts for street/strip? [Re: AndyF] #2815010
08/30/20 06:12 AM
08/30/20 06:12 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Replaced the I/P and O/P shaft when the ring and pinion failed. JFI the upgraded O/P shafts don't have the worm splines machined in for a speedo drive.
Re: 727 parts for street/strip? [Re: AndyF] #2815024
08/30/20 08:21 AM
08/30/20 08:21 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I too used a freeze plug for the speedometer gear hole but made a small retainer tab to make sure it doesn’t come out. Mine has never moved but I just wanted a little insurance that it couldn’t come out.
Re: 727 parts for street/strip? [Re: justinp61] #2815064
08/30/20 11:19 AM
08/30/20 11:19 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've seen the plug come out of a speedometer hole more than once...Not sure if any sealant was used or not, but I'd make sure there's a clip or something just as extra insurance.
Re: 727 parts for street/strip? [Re: DusterKid] #2815296
08/30/20 11:30 PM
08/30/20 11:30 PM
Confusion
Dodger440 Offline
Dodger440  Offline
Confusion
I wouldn't use a freeze plug to block off the speedometer adapter hole, I have seen those come out before causing a huge fluid leak. These are available in the transmission for sale section, they fit great and can't fall out.
Re: 727 parts for street/strip? [Re: Dodger440] #2815415
08/31/20 10:50 AM
08/31/20 10:50 AM
A727Tflite Offline
A727Tflite  Offline
Very close in design to the plug used on the factory SS Hemi cars back in the day.
I like the threaded hole to ease removal though.
Re: 727 parts for street/strip? [Re: Dodger440] #2815631
08/31/20 06:44 PM
08/31/20 06:44 PM
AndyF Offline OP
AndyF  Offline OP
I had a design for a plug like that but then decided to go with a simple retainer on top of the cup plug. Either way should prevent an issue.
Re: 727 parts for street/strip? [Re: AndyF] #2815641
08/31/20 07:26 PM
08/31/20 07:26 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
I’m sure Mr. Anecdotal will comment, but, it’s no different than installing a block core plug. I don’t get the concern. Peen the center and don’t worry about it.
Re: 727 parts for street/strip? [Re: AndyF] #2815660
08/31/20 08:28 PM
08/31/20 08:28 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
What'd your retainer end up looking like?
Re: 727 parts for street/strip? [Re: mopowers] #2816523
09/03/20 03:16 AM
09/03/20 03:16 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Just out of interest, did/can you weigh the 5 pinion planetary against any others?
Re: 727 parts for street/strip? [Re: Alchemi] #2816599
09/03/20 10:39 AM
09/03/20 10:39 AM
AndyF Offline OP
AndyF  Offline OP
I didn't put it on the scale. It was heavier but not super heavy. Maybe 5 lbs while the factory aluminum 4 pinion one that I had in there was 3.5 lbs or something like that. So it does add weight to the assembly but it can be offset with a lightweight sun shell or the aluminum park gear or something else.
Re: 727 parts for street/strip? [Re: AndyF] #2817771
09/06/20 11:50 AM
09/06/20 11:50 AM
AndyF Offline OP
AndyF  Offline OP
I have a few different input shafts to choose from so I'm trying to decide which is the best to use. Are the later generation with the three sealing rings better than the earlier two ring style? I'm not sure I understand the oiling difference. The early ones have a hole in the shaft but the later one doesn't. So there must have been a change along the way but I haven't found any reference yet to what else changed.
Re: 727 parts for street/strip? [Re: AndyF] #2817848
09/06/20 02:57 PM
09/06/20 02:57 PM
A727Tflite Offline
A727Tflite  Offline
You cannot interchange the input shaft unless you keep the matching reaction shaft support.
Re: 727 parts for street/strip? [Re: A727Tflite] #2817853
09/06/20 03:22 PM
09/06/20 03:22 PM
AndyF Offline OP
AndyF  Offline OP
I have mating parts, just wondering if one is better than the other. I assume the late model 3 ring must have been enough of an improvement for the factory guys to switch. But it doesn't seem to be a big deal for the aftermarket. Looks like the most popular aftermarket input shaft is the two ring style although A&A does sell a super duty input shaft that is for the three ring config. Maybe it is a better design but most people don't have the matching parts?
Re: 727 parts for street/strip? [Re: AndyF] #2817908
09/06/20 05:13 PM
09/06/20 05:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On the 3-ring input, the middle and rear ring (actually on the clutch retainer) feed the rear clutch, the middle and front ring are for the lockup converter. No advantage to use it on a non-lockup trans.
Re: 727 parts for street/strip? [Re: John_Kunkel] #2817917
09/06/20 05:27 PM
09/06/20 05:27 PM
AndyF Offline OP
AndyF  Offline OP
Okay, that makes sense. I have parts from a 1978 big block 727 (non-lockup) on hand as well as parts from a lock-up 727. The input shaft on the non-lockup is solid between the middle and front ring while on the lockup input shaft there is a hole there. The input shaft from the non-lockup '78 trans is in nice shape so I was planning on using it along with the late model pump and reaction shaft.
Is there a difference between the pump and reaction shaft in the lockup vs. the non-lockup 727 or can I use either on? I looked them over and didn't see a difference but there must be some sort of additional fluid passage in the lockup one that I missed.
Page 3 of 4 1 2 3 4
