Lubricant Behind Headlight Buckets? #2811191
08/20/20 05:58 PM
08/20/20 05:58 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Looking through engineering documents and found a reference to lubricant applied behind the headlight buckets. That’s a new one for me. The drawing calls for “Lubricant 2206020” to be applied to the three ridges on the bucket where they make contact with the headlight seat area on the front fender.
Any ideas on the purpose? There are various types of lubricants identified in these docs. The only other refs to this type of lube I could find have it applied to the base of the turn signal switch and on a portion of the steering column.
5A50B818-AE29-4F89-B236-F71240DB0902.jpeg68BD2C8E-FDAF-4FC7-9087-3B2CFF1E3455.jpegB1BCE071-03DC-48D1-9E79-659BA3D2FC60.jpegAE34A4B0-82A6-4E9D-B226-38E6FA2006DD.jpeg
Re: Lubricant Behind Headlight Buckets? [Re: floyd] #2811284
08/20/20 08:29 PM
08/20/20 08:29 PM
A727Tflite Offline
A727Tflite  Offline
The old “headlight oil” trick played on my sister. I guess it wasn’t a trick after all.
Re: Lubricant Behind Headlight Buckets? [Re: A727Tflite] #2811296
08/20/20 08:42 PM
08/20/20 08:42 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Yep, I thought of muffler bearing grease as I was drafting this.
I wonder if it was a dielectric grease or something else to assist with grounding? I can’t imagine squeaking was an issue.
Re: Lubricant Behind Headlight Buckets? [Re: floyd] #2811449
08/21/20 08:51 AM
08/21/20 08:51 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
When you adjust the headlights the buckets move against the core support. I am assuming the lubricant was there to help the bucket move smoothly.
Re: Lubricant Behind Headlight Buckets? [Re: 6PakBee] #2811500
08/21/20 10:23 AM
08/21/20 10:23 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Makes more sense than an electric issue. Thanks
Re: Lubricant Behind Headlight Buckets? [Re: 6PakBee] #2811713
08/21/20 06:13 PM
08/21/20 06:13 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
i would use a waterproof grease. Dont think its a big deal , but back in the day cars were driven, daily and in the salt. So just to help when you replaced the bulb so you could re- align
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Lubricant Behind Headlight Buckets? [Re: floyd] #2811949
08/22/20 01:53 PM
08/22/20 01:53 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Multipurpose lithium base
https://www.zoro.com/static/cms/enhanced_pdf/Z19E7zff.PDF
I'm curious about the plant i.d,, is that canada?
Re: Lubricant Behind Headlight Buckets? [Re: floyd] #2812438
08/24/20 01:52 AM
08/24/20 01:52 AM
Me thinks some skunk at Faxons is having there idea of fun messing with us car guys rant down
Re: Lubricant Behind Headlight Buckets? [Re: Cab_Burge] #2814589
08/29/20 12:21 AM
08/29/20 12:21 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I thought that at first, then thinking perhaps canada potential for rust?
Re: Lubricant Behind Headlight Buckets? [Re: srt] #2814647
08/29/20 10:05 AM
08/29/20 10:05 AM
A727Tflite Offline
A727Tflite  Offline
How many cars have you had the headlights and buckets out of and seen grease?
Me, never. Not saying they didn’t do it but strange never to see grease. Only sense it makes is to keep the headlight free from rust.
Re: Lubricant Behind Headlight Buckets? [Re: 6PakBee] #2814684
08/29/20 11:47 AM
08/29/20 11:47 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
iagree
Re: Lubricant Behind Headlight Buckets? [Re: A727Tflite] #2815036
08/30/20 09:28 AM
08/30/20 09:28 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Anyone know what CAG Plants are? I wonder why the directive denotes that.
Re: Lubricant Behind Headlight Buckets? [Re: srt] #2815041
08/30/20 09:56 AM
08/30/20 09:56 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm going out on a limb here, Chassis And Glass? Maybe to differentiate them from transmission plants and engine plants?
Re: Lubricant Behind Headlight Buckets? [Re: 6PakBee] #2815051
08/30/20 10:27 AM
08/30/20 10:27 AM
A727Tflite Offline
A727Tflite  Offline
Car Assembly Group.
Re: Lubricant Behind Headlight Buckets? [Re: A727Tflite] #2815060
08/30/20 10:53 AM
08/30/20 10:53 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by Transman
Car Assembly Group.
Re: Lubricant Behind Headlight Buckets? [Re: floyd] #2815257
08/30/20 09:45 PM
08/30/20 09:45 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Details I knew not.
Was working in shop today and checked an unrestored 68 b body that has crystallized red grease on those ribs.
Odd thing is until I take it apart only the driver side seems to have excess globbed on. I flipped up a small bit with a small screwdriver and it appears to be a red color grease. If you zoom in you may see a glint of the red color.
Re: Lubricant Behind Headlight Buckets? [Re: srt] #2815804
09/01/20 09:54 AM
09/01/20 09:54 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
A thought on Assy line procedure. some workers would use none, or a small amount that would become unnoticeable over time, others would glop it on and residue would remain over time?
Re: Lubricant Behind Headlight Buckets? [Re: srt] #2815911
09/01/20 04:32 PM
09/01/20 04:32 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
iagree I think it's naive to think that all workers on the line followed the specific procedures all the time.
Re: Lubricant Behind Headlight Buckets? [Re: 6PakBee] #2816042
09/01/20 10:41 PM
09/01/20 10:41 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Who'd want greasy fingers anyway?
Re: Lubricant Behind Headlight Buckets? [Re: srt] #2816343
09/02/20 05:38 PM
09/02/20 05:38 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Now I have to go & check my NOS ones, I would just use white lube myself.
