Track Results 508" B1
#2815620
08/31/20 06:15 PM
08/31/20 06:15 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Overall I had a good first outing. Participated in a track rental from 9-1 and made 8 passes. First 2 were full passes and then I moved to getting my throttle stop dialed in. Then we had a bracket race that evening, time trials started at 6pm.
At the end of the day what I learned: - My old 540" -1 headed motor made more power than I thought it did. (probably closer to 880 since this one made 866) - I miss the snappiness and torque of alcohol. (much smaller wheelie) - I miss the cooling properties of alcohol (I'm going to need to replace my radiator - I'm happy with the motor and knew building it that I wasn't a max-effort build. 2nd pass -- 1.401 --- 3.946 --- 6.122 @112.35 --- 8.018 --- 9.634 @139.06 (83.1 degrees, 77% humidity, 29.16 barometer, 3387 altitude 10:30am) Last pass - 1.376 --- 3.901 --- 6.04 @114.01 (75.6 degrees, 83% humidity, 29.17 barometer, 2729 altitude 10:45pm)
So I think i think that last pass would have been a 9.55 in the 1/4.
The best pass I made with the other motor was 9.29 but that was on alcohol and without the mufflers and exhaust and a buddy who weighs 50lbs less that I do and this motor probably weights 100lbs less, I believe those are worth 3-4 tenths
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Track Results 508" B1
[Re: unknown]
#2815630
08/31/20 06:37 PM
08/31/20 06:37 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why did you move away from using alcohol
[Re: pittsburghracer]
#2815639
08/31/20 07:18 PM
08/31/20 07:18 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
What's the car weigh with you in it. Nice hits!
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 440Jim]
#2815799
09/01/20 09:47 AM
09/01/20 09:47 AM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What’s it weigh on the starting line now with the new engine?
[Re: fast68plymouth]
#2815819
09/01/20 10:34 AM
09/01/20 10:34 AM
WadeMetzinger
Tulsa, Ok
Tire size - MT 14x32 stiff slidewalls 3074S
Move from alcohol to gas - My carb was a 20 year old Chuck Nuytten 1050 alcohol carb. I had been running an under carb throttle stop and with the B1 intake I wouldn't have room under the hood. So I needed/wanted to do something about the clearance and I wanted a new shinny fancy updated carb and really liked APDs Max Speed with the built in throttle stop. So that was the carb I chose and then I had to decide on gas or alcohol. I spoke to APD, local .90 racers, Luke Bogacki and others and they all said that gas is more predicable from day to day and since NHRA .90 races typically span multiple days I was leaning towards gas. Alcohol is more consistent if you get a time trial before eliminations but when NHRA racing, many times your first pass down the track is elimination round. Machinist also like gas over alcohol because how hard alcohol is on cylinder walls, and it's so much easier to start on initial start ups each time out, especially in cooler weather. Several of the local guys have done back to back testing with gas and alcohol both on dyno and on track and they aren't seeing much increase with alcohol and on track they are seeing more mph on gas but they are big motors with 15:1 compression so alcohol would have made a significant difference on my motor. (sort of regretting my decision to move to gas) My cooling system isn't doing very good keeping the motor cool so I'll probably need to replace the radiator with a bigger one or just go back to alcohol.
Weight - With the old motor it weighed 3,050lbs so I'm guessing it weighs 2,950lbs with the aluminum block.(KB block was close to 150lbs lighter but the B1 intake and spacers weigh a lot more than the Indy intake) I'll get it weighed when I go to the Dallas double divisional on 9/18. I weigh 230lbs so that would add up to approximately 3,180 so round up to 3,20lbs race weight.
The torque converter feels really tight (tighter than it used to) but I never got around to checking the stall with the new motor so I'll check that next time out. It's a 9" Dynamic. It used to stall 5,500.
[Re: WadeMetzinger]
#2815825
09/01/20 10:48 AM
09/01/20 10:48 AM
fast68plymouth
So. Burlington, Vt.
According to the Moroso chart, that 9.63 and just over 139mph line up almost exactly.
At 3200lbs it’s showing 665hp.
#2815826
09/01/20 10:50 AM
09/01/20 10:50 AM
B3422W5
Portage,michigan
At 3200lbs it’s showing 665hp. Sounds about right. Guy who bought my old Duster had motor dyno’ed by Best Machine. 708 on dyno. 422 W5 motor Went 9.62@140 at 3220 with driver. Stouter than when i had it, he made some nice upgrades. Plus lighter driver..lol
#2816107
09/02/20 07:27 AM
09/02/20 07:27 AM
Posts: 287 PA
Harry's Taxi 2
PA
At 3200lbs it’s showing 665hp. Have you found the Moroso slide rule to be fairly accurate compared to actual dyno results? I've heard a few comp elim. and older pro stock guys say the were/are fairly accurate, but there sure seems to be quite a disparity between moroso and Wallace and actual dyno's lately.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: HardcoreB]
#2816147
09/02/20 10:08 AM
09/02/20 10:08 AM
fast68plymouth
So. Burlington, Vt.
Have you found the Moroso slide rule to be fairly accurate compared to actual dyno results? I have. But you have to look at the whole situation....... da, how good the car is, head wind or not, track prep, etc....... and then there is always the question about how accurate the dyno numbers are. In decent(but not killer) air, a good stock or super stock car will outrun the Moroso chart..... and often by quite a bit. (Using the Moroso chart, my friends Stocker has run enough speed show the hp to be 108% of what the STP power was on the dyno. Even racing in Vegas the car shows within 5% of the STP power, and that’s a track with an altitude adjustment factor). A mediocre street/strip car may have a hard time showing within 15% of the dyno numbers, and a typical half way decent bracket car should be able to get within 10%. And a car that’s not set up for the track at all might show numbers that are 20-25% low. If you look at the post by gregsdart about his last track outing with his new fresh-off-the -dyno combo....... he is within 10%. Greg’s 154 speed shows 845hp, motor made 920 on the dyno....... STP corrected. 8.2% correction. It just happens to work out that Greg’s uncorrected dyno numbers are very close to the what the on track numbers show. After all, you’re not racing in corrected air. Plugging Wades results into the Wallace calculator to correct the run to zero DA shows 9.36@143. 143@3200 shows 720hp on the Moroso chart, which still works out to over a 16% correction to get back to 860hp. However, if you take the fuel flow and bsfc numbers from Wades dyno sheet, and calculate the uncorrected HP, you come up with a number that’s just under 700hp. Much closer to what the in car performance was for his last outing.
#2816537
09/03/20 06:22 AM
09/03/20 06:22 AM
Posts: 287 PA
Harry's Taxi 2
PA
Have you found the Moroso slide rule to be fairly accurate compared to actual dyno results? I have. But you have to look at the whole situation....... da, how good the car is, head wind or not, track prep, etc....... and then there is always the question about how accurate the dyno numbers are. In decent(but not killer) air, a good stock or super stock car will outrun the Moroso chart..... and often by quite a bit. (Using the Moroso chart, my friends Stocker has run enough speed show the hp to be 108% of what the STP power was on the dyno. Even racing in Vegas the car shows within 5% of the STP power, and that’s a track with an altitude adjustment factor). A mediocre street/strip car may have a hard time showing within 15% of the dyno numbers, and a typical half way decent bracket car should be able to get within 10%. And a car that’s not set up for the track at all might show numbers that are 20-25% low. If you look at the post by gregsdart about his last track outing with his new fresh-off-the -dyno combo....... he is within 10%. Greg’s 154 speed shows 845hp, motor made 920 on the dyno....... STP corrected. 8.2% correction. It just happens to work out that Greg’s uncorrected dyno numbers are very close to the what the on track numbers show. After all, you’re not racing in corrected air. Plugging Wades results into the Wallace calculator to correct the run to zero DA shows 9.36@143. 143@3200 shows 720hp on the Moroso chart, which still works out to over a 16% correction to get back to 860hp. However, if you take the fuel flow and bsfc numbers from Wades dyno sheet, and calculate the uncorrected HP, you come up with a number that’s just under 700hp. Much closer to what the in car performance was for his last outing. Thanks for the reply. I've never personally had a dyno vs. moroso chart comparison but a couple of friends cars with dyno'd engines seem way off compared to the moroso chart on the mph.(even accounting for corrections as you've mentioned above) I attribute that to the latest fad of loosey-goosey converters. the part I've used on the moroso chart as a guide is the mph vs e.t. I work on which ever is the weaker of the two and once you get them in line, it seems that's about as quick/fast as that particular combo is going to go.
[Re: Harry's Taxi 2]
#2816540
09/03/20 07:07 AM
09/03/20 07:07 AM
Posts: 570 UK
rb446
UK
Interesting stuff...I've always used Wallace, I input the weight and to get the ET/mph run I adjust the fwhp no. till it gets close on mph, but generally Wallace is 1 mph up especially if you 60 a bit better than it shows on the chart which tends to be the case mostly. For instance as an example, and not to hijack the thread, our 3828 r/weight car 60's in the 1.43's, normally runs 125+126, has run 127.5........dyno'd here@695hp,... this is what shows@3828 with an input of 663fwhp with FULL EXHAUST>
Power to Weight Ratio: 5.77 60 Foot E.T. : 1.45 1/8 Mile E.T. : 6.59 1/8 Mile Trap Speed : 103.09 1/4 Mile E.T. : 10.45 1/4 Mile Trap Speed : 128
The tickets show lower increments apart from the ET which is accurate and within 4.5% of the dyno, I don't think the car is that good, perhaps the dyno is?.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2816571
09/03/20 09:11 AM
09/03/20 09:11 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Has anyone even seen a Dyno that tested LOW on horsepower numbers. Yaaa me either. Lol.
#2816581
09/03/20 09:36 AM
09/03/20 09:36 AM
fast68plymouth
So. Burlington, Vt.
This run shows waaaaay more power on Wallace than what the motor actually made for STP power.
In this example, there is less disparity between the projected required hp between the MPH/ET on the Moroso chart vs the Wallace calculator.
#2816617
09/03/20 11:35 AM
09/03/20 11:35 AM
Posts: 2,859 Pattison Texas
CSK
Pattison Texas
As it has been pointed out before to me by Dwayne, the Moroso slide is NET flywheel HP.
#2816718
09/03/20 03:37 PM
09/03/20 03:37 PM
Posts: 3,510 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Has anyone even seen a Dyno that tested LOW on horsepower numbers. Yaaa me either. Lol. I dyno my engines at Patterson-Elite. They say they have had folks get mad at them because their dyno (Superflow) did not show as much horsepower and the same engine made on other dyno. Some dynos have a reputation of being "happy". Theirs is not one of those.
