Re: 727 parts for street/strip?
[Re: AndyF]
#2811087
08/20/20 02:16 PM
08/20/20 02:16 PM
Posts: 9,871 MI, usa
dvw
MI, usa
That looks like a classic fatigue failure since it started on an edge and is square across the face. A torsional failure would have more of a spiral shape. So you're probably correct, the shock of the reared end failure probably started a crack and then it just spread over time.
I have 5 or 6 core transmissions to pick parts from so I'm going thru them and grabbing the best parts from each. Most of them have good internals but a couple of them have toasted rear drums. Not sure why, but the rear bands are shot and the drums show signs of being overheated. So I'll probably toss those parts unless they are worth something as cores. Rear drum is only used in reverse and 1st gear braking. There shouldnt be an issue with those parts unless it was a plow truck. Doug
[Re: AndyF]
#2814949
08/29/20 10:44 PM
08/29/20 10:44 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Appears you’re already done, but I think you would have/still can, benefit from the modification that dvw’s son did to his. He used the park hub as an output shaft tone wheel for speed input. Drill and thread the housing. You of all people should be able to put that to good use.
[Re: AndyF]
#2815010
08/30/20 06:12 AM
08/30/20 06:12 AM
Posts: 2,933 A shed in England
Tig
A shed in England
Replaced the I/P and O/P shaft when the ring and pinion failed. JFI the upgraded O/P shafts don't have the worm splines machined in for a speedo drive.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: AndyF]
#2815660
08/31/20 08:28 PM
08/31/20 08:28 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I had a design for a plug like that but then decided to go with a simple retainer on top of the cup plug. Either way should prevent an issue. What'd your retainer end up looking like?
[Re: Alchemi]
#2816599
09/03/20 10:39 AM
09/03/20 10:39 AM
Posts: 31,069 Oregon
AndyF
Just out of interest, did/can you weigh the 5 pinion planetary against any others? I didn't put it on the scale. It was heavier but not super heavy. Maybe 5 lbs while the factory aluminum 4 pinion one that I had in there was 3.5 lbs or something like that. So it does add weight to the assembly but it can be offset with a lightweight sun shell or the aluminum park gear or something else.
[Re: AndyF]
#2817848
09/06/20 02:57 PM
09/06/20 02:57 PM
Posts: 3,089 Michigan
A727Tflite
I have a few different input shafts to choose from so I'm trying to decide which is the best to use. Are the later generation with the three sealing rings better than the earlier two ring style? I'm not sure I understand the oiling difference. The early ones have a hole in the shaft but the later one doesn't. So there must have been a change along the way but I haven't found any reference yet to what else changed. You cannot interchange the input shaft unless you keep the matching reaction shaft support.
[Re: AndyF]
#2817908
09/06/20 05:13 PM
09/06/20 05:13 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
On the 3-ring input, the middle and rear ring (actually on the clutch retainer) feed the rear clutch, the middle and front ring are for the lockup converter. No advantage to use it on a non-lockup trans.
[Re: John_Kunkel]
#2817917
09/06/20 05:27 PM
09/06/20 05:27 PM
AndyF
On the 3-ring input, the middle and rear ring (actually on the clutch retainer) feed the rear clutch, the middle and front ring are for the lockup converter. No advantage to use it on a non-lockup trans. Okay, that makes sense. I have parts from a 1978 big block 727 (non-lockup) on hand as well as parts from a lock-up 727. The input shaft on the non-lockup is solid between the middle and front ring while on the lockup input shaft there is a hole there. The input shaft from the non-lockup '78 trans is in nice shape so I was planning on using it along with the late model pump and reaction shaft. Is there a difference between the pump and reaction shaft in the lockup vs. the non-lockup 727 or can I use either on? I looked them over and didn't see a difference but there must be some sort of additional fluid passage in the lockup one that I missed.
