93 CTD down on power - help! #2814818
08/29/20 05:46 PM
08/29/20 05:46 PM
A727Tflite Offline OP
93 Cummins, 177K miles, auto trans.
Fresh fuel filter 10/2020.
New air filter a month ago.
All original under the hood.
This thing has lost a lot of power - labors pulling 8K lbs.
Best I can tell I am getting 15lbs. boost max. Not sure if that is good or not.
If it is, any ideas on what to look for - the service manual list a host of possible culprits, just wondering if there is something common that goes south on these that could be my issue.
Re: 93 CTD down on power - help! [Re: A727Tflite] #2814878
08/29/20 08:24 PM
08/29/20 08:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Make sure it has full throttle. If an automatic make sure the tranny is full. These are two simple items I have seen with low power complaints.
Re: 93 CTD down on power - help! [Re: A727Tflite] #2814891
08/29/20 08:45 PM
08/29/20 08:45 PM
Maryland
ro23_j Offline
ro23_j  Offline
Maryland
I have a 91 CTD and I pulled the fuel tank so I could replace all of the rusted brake lines.
I found that the fuel supply line had some pinholes from rust and was seeping fuel. Also, the vent on top of the tank appeared to be blocked with dirt. I replaced the fuel line and cleaned the vent and when I drove it for the first time, it was like a new truck. The last time I towed with it before I replaced the brake lines, it felt like it was down on power.
My assumption is that it was either sucking air through the rusted supply line and/or the vent was not allowing enough air into the tank. Might be worth a look.
Re: 93 CTD down on power - help! [Re: ro23_j] #2814915
08/29/20 09:34 PM
08/29/20 09:34 PM
I had already checked for full throttle, made sure the fuel shut off valve was not partially engaged.
I had read about the possibility of the fuel tank having issues, going to consider dropping the tank but I think according to the manual, they want you to test fuel line vacuum at the lift pump, or fuel pressure at the lift pump outlet. Need to gather the fittings for that.
Not sure what is faster, dropping the tank or checking vacuum and pressure.
Maybe since this truck is 27 years old it makes sense to drop the tank and clean it out and check for condition.
Thanks for the info.
Re: 93 CTD down on power - help! [Re: NITROUSN] #2814916
08/29/20 09:35 PM
08/29/20 09:35 PM
What does trans fluid level have to do with low power? Just wonderin’
Re: 93 CTD down on power - help! [Re: A727Tflite] #2814926
08/29/20 09:51 PM
08/29/20 09:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Ran into a complaint years back. The guy had a rubber transmission line blow off. He never told us the whole story at first. He added some fluid but he did not get it full. The truck was a dog and his complaint was low power. We added several quarts and it was back to normal. I can only attribute the condition to the large converter fluid capacity. Lower fluid did not allow the transmission/converter to make power. It did not act like a low fluid problem. Just a suggestion.
Re: 93 CTD down on power - help! [Re: A727Tflite] #2814929
08/29/20 09:56 PM
08/29/20 09:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I might be old.... but I’m not VE pump old! I thought your explanation of “lack of power” described a stock one to a T!
Any witness marks around the pump mounting bolts? Years of vibration may have allowed the pump to move.... I know, I’m grasping here...
Re: 93 CTD down on power - help! [Re: A727Tflite] #2814962
08/29/20 11:19 PM
08/29/20 11:19 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Maybe a collapsed exhaust pipe (some are double walled) or a clogged muffler.
Re: 93 CTD down on power - help! [Re: RTSrunner] #2815007
08/30/20 05:30 AM
08/30/20 05:30 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I've heard that the rubber tip of the KSB can come loose and partially block the incoming fuel.
Angry white pureblood male
Re: 93 CTD down on power - help! [Re: ruderunner] #2815080
08/30/20 12:12 PM
08/30/20 12:12 PM
Thanks for all the tips.
It has a newer Bullly Dog exhaust system on it, may be two years old, three years max.
I have a diesel expert going to look at it, I’m backlogged with work on other projects.
Re: 93 CTD down on power - help! [Re: A727Tflite] #2815150
08/30/20 04:09 PM
08/30/20 04:09 PM
N
NITROUSN Offline
NITROUSN  Offline
N
This is a copy and paste from Geno's Garage.
A check of the low-power-complaint basics.
Following is a list of easy-to-do items the owner can perform
:- check for quality of fuel-
check for full travel of the throttle lever at the fuel pump-
check all turbo-to-intercooler and intercooler-to-intake manifold hoses and clamps for a tight fit-
check the condition of your fuel filter-
check for fuel inlet restriction-
check the condition of your air filter-
check for exhaust leaks prior to the turbocharger-
check for exhaust system restriction
for automatic trucks; check your transmission fluid level
Re: 93 CTD down on power - help! [Re: NITROUSN] #2815199
08/30/20 07:26 PM
08/30/20 07:26 PM
:- check for quality of fuel- good
check for full travel of the throttle lever at the fuel pump- done
check all turbo-to-intercooler and intercooler-to-intake manifold hoses and clamps for a tight fit- done
check the condition of your fuel filter- new
check for fuel inlet restriction- pending
check the condition of your air filter- new
check for exhaust leaks prior to the turbocharger- none
check for exhaust system restriction - how? At idle it feels like normal exhaust pulses
for automatic trucks; check your transmission fluid level. done.
Re: 93 CTD down on power - help! [Re: A727Tflite] #2815233
08/30/20 08:40 PM
08/30/20 08:40 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I am not sure on the boost level on the 1st gen trucks. 15 may be close. I doubt it is over 20. Generally if you do not have enough fuel you can not make boost. I have heard of weak lift pumps causing a lack of power. Not sure what the fuel pressure should be for that style lift pump but as long as it has positive pressure to supply the injection pump it should be enough to give the pump all it needs. Dirty of partially plugged injectors could also play in.
Re: 93 CTD down on power - help! [Re: NITROUSN] #2815243
08/30/20 09:20 PM
08/30/20 09:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Another thought if you hold it in first gear what rpm does it reach before the governor kicks in? Will it do the same in each gear? I know when the throttle position sensor act up you loose a top gear same with the speed sensor which I believe you would be on to those symptoms.
Re: 93 CTD down on power - help! [Re: NITROUSN] #2815260
08/30/20 09:56 PM
08/30/20 09:56 PM
Guitar Jones Offline
Mine can hit 36 on a good day. Lack of fuel is the usual culprit. Fuel lines sucking air, weak lift pump and clogged fuel filter are the most likely. When was the last time you changed the fuel filter? Apparently it's still in the future, unless you live in a time warp or something.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 93 CTD down on power - help! [Re: A727Tflite] #2815464
08/31/20 12:12 PM
08/31/20 12:12 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Is it blowing Any more smoke than normal?? look at the intercooler hoses/tubes. Make sure they are fully connected and not leaking. Also look at the intercooler for leaks.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 93 CTD down on power - help! [Re: W.I.N. Racing] #2815600
08/31/20 05:00 PM
08/31/20 05:00 PM
Still waiting for the expert to call me.
New filter, I can’t get more than 15 boost, all the external air lines and rubber flex connections are good and tight, only some dark smoke on startup.
It was never a rocket ship, more like a peppy brick but I pulled twice the load out of Portland in 2013 than I just did and it felt pretty strong then compared to now.
Re: 93 CTD down on power - help! [Re: A727Tflite] #2815646
08/31/20 07:51 PM
08/31/20 07:51 PM
Adjust the valves. Check the fuel pressure before and after the filter. Pull the fuel shut off solenoid and inspect it. They have been known for the rubber to come apart and clog the fuel feed to the VE pump. Past that pull the injectors and have them cleaned and pop tested. Remove the intake hose and check the turbo, make sure the blades aren't damaged and it spins freely. Make sure the shaft is tight and the blades aren't scraping the housing.
Re: 93 CTD down on power - help! [Re: Guitar Jones] #2816060
09/02/20 12:36 AM
09/02/20 12:36 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
This may not be your problem but just throwing it out there. Back in 1998 I had a late build 1990 CTD with an Intercooler. It had lower power than it should have had. Turned out to be the aluminum intercooler had a hole in it from corrosion.
Re: 93 CTD down on power - help! [Re: hemi70se] #2818032
09/06/20 11:29 PM
09/06/20 11:29 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
As has been said, check the intercooler. Pull the hoses and plug one end and make up a fitting to clamp in the other end with a valve and a pressure gauge. Air it up to about 30 psi and close the valve. If it loses more than 5 psi in 15 seconds, it's FUBAR. For your problem it would have to have a substantial leak so it should pretty much go to zero as soon as you close the valve.
How much fuel pressure? No fuel, no boost, no power.
According to this article, 25 psi is minimum.
Some good info for both P pump and VE.
https://www.dieseltuff.com/instructions/
Kevin
