Final Nail in the Coffin for the "Orange Box" #2814232
08/28/20 09:27 AM
08/28/20 09:27 AM
California, U.S.A.
Torquemonster440 Offline OP
California, U.S.A.
Welp, the newest episode of Engine Masters confirms the age old debate over whether or not the old standard "Orange Box" ignition controller is a worthwhile option in comparison to a modern digital ignition. I've been on the fence about upgrading my ignition recently.Years ago I recurved my distributor at home, it works well but at its core it's at least 20 years old. When paired with my equally old orange box I think I'm at a disadvantage in terms of all out performance, not to mention reliability. Watch the episode if you get a chance, it's a good one. New MSD system... Here I Come. up
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Final Nail in the Coffin for the "Orange Box" [Re: Torquemonster440] #2814241
08/28/20 10:04 AM
08/28/20 10:04 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I never used the orange box, but used to use the chrome box. worked great to 7200rpm on my 340. I then decided to upgrade to Mallory, then MSD, then Jacobs, then MSD, then Ice Ignition. I think the Jacobs had the best performance because the engine seemed to run cleaner and crisper. Out of all these boxes i think the chrome box was a very good one.
Re: Final Nail in the Coffin for the "Orange Box" [Re: mopar dave] #2814249
08/28/20 10:14 AM
08/28/20 10:14 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I've used the MSD 6AL with a stock, recurved magnetic pickup Mopar distributor combo for 20 years.
Stone reliable and you can get all the parts at the local parts house.
Having a rev limiter and things like timing control is all the more reason to convert.
'63 Dodge 330
11.19 @ 121 mph
Re: Final Nail in the Coffin for the "Orange Box" [Re: Torquemonster440] #2814376
08/28/20 01:48 PM
08/28/20 01:48 PM
AndyF Online content
AndyF  Online Content
I dyno tested some Mopar ignition boxes years ago and they all performed so poorly that I tossed all that stuff and moved on. Above 6000 rpm all the ones I tested had issues.
Re: Final Nail in the Coffin for the "Orange Box" [Re: AndyF] #2814394
08/28/20 02:13 PM
08/28/20 02:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Last time I used one of those - a chrome box - Jimmy Carter was president.
Re: Final Nail in the Coffin for the "Orange Box" [Re: CMcAllister] #2814410
08/28/20 02:44 PM
08/28/20 02:44 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
i tried a revenator .. did not work for me
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Final Nail in the Coffin for the "Orange Box" [Re: bigdad] #2814478
08/28/20 06:40 PM
08/28/20 06:40 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Me neither.
Master, again and still
Re: Final Nail in the Coffin for the "Orange Box" [Re: DaveRS23] #2814514
08/28/20 08:42 PM
08/28/20 08:42 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve had good luck with the FBO unit so far.
Re: Final Nail in the Coffin for the "Orange Box" [Re: fastmark] #2814553
08/28/20 09:55 PM
08/28/20 09:55 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
As my cars stock ignitions die, I'm replacing them w hidden GM 4 pin HEI modules.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Final Nail in the Coffin for the "Orange Box" [Re: HemiRick] #2814563
08/28/20 10:14 PM
08/28/20 10:14 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
My neighbor just did this on a Dart he's building. It's a neat setup!
'63 Dodge 330
11.19 @ 121 mph
Re: Final Nail in the Coffin for the "Orange Box" [Re: GY3] #2814650
08/29/20 10:14 AM
08/29/20 10:14 AM
Originally Posted by GY3
[quote=HemiRick]As my cars stock ignitions die, I'm replacing them w hidden GM 4 pin HEI modules.
whats the best one to use, an OE black one from the 70's or one of the aftermarket ones?
Re: Final Nail in the Coffin for the "Orange Box" [Re: HemiRick] #2814666
08/29/20 11:09 AM
08/29/20 11:09 AM
AAAAH, GM parts on a Mopar down tsk stirthepot devil
Re: Final Nail in the Coffin for the "Orange Box" [Re: AndyF] #2814866
08/29/20 08:03 PM
08/29/20 08:03 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
So did Mopar Performance - Tossed
Back in the days of Direct Connection , there was actually some pretty good Ignition Boxes along with coils
Now try piecing together a decent so called factory oem system using all this Chinese mismatched crap available today
It’s truly amazing how many different ECU / Ignition modules / coils fail above 5,000 RPMs
In reality FBO is about your only COMPLETE system if you want to stay Inductive
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Final Nail in the Coffin for the "Orange Box" [Re: bee1971] #2814870
08/29/20 08:09 PM
08/29/20 08:09 PM
Yeah that is my take on it to. 30 or 40 years ago the MP stuff was probably okay to use but when I ran my tests 20 years ago the stuff was hit or miss at best. My guess is that it is even worse now. I've seen some photos of what the insides of the Mopar ignition boxes look like now and they are all offshore junk with cheap parts. Chinese slave labor type of components.
Re: Final Nail in the Coffin for the "Orange Box" [Re: AndyF] #2814893
08/29/20 08:50 PM
08/29/20 08:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Be careful. I'm in FB jail for telling the truth about some of the stuff produced by our Far East brothers and sisters. Apparently Mr Z thinks they are great and the things they make are not "C******* trash"..
It's all suspect, even the "good" MSD stuff. Gotta love equity firms.
Not sure I'd consider a 1970s GM solution to be the right answer though.
Re: Final Nail in the Coffin for the "Orange Box" [Re: CMcAllister] #2814927
08/29/20 09:51 PM
08/29/20 09:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
In my version of “purple shafts and pinion snubbers” mopar guy ways.... I’m still using a MSD 6AL. I just can’t make that leap to the programmable stuff. Prob has something to do with thinking about how my Racepak fought me and won most the time. Do I REALLY want to rely on stuff like that to run the car??. laugh2
Re: Final Nail in the Coffin for the "Orange Box" [Re: CMcAllister] #2815017
08/30/20 07:27 AM
08/30/20 07:27 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Wow, what ever happened to free speech? It sad how this country seems to be controlled by very few big moguls that think they know the answers to everything and us lowly sheep need to just follow what they think is best for us. Somehow they seem to be the richest, as well. I bet they won’t give up their wealth and share that!
Re: Final Nail in the Coffin for the "Orange Box" [Re: Torquemonster440] #2815037
08/30/20 09:47 AM
08/30/20 09:47 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
MSD Test proven all the way around.... Plenty of them in the winners circle... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Final Nail in the Coffin for the "Orange Box" [Re: Torquemonster440] #2815096
08/30/20 01:04 PM
08/30/20 01:04 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The best Chrysler ECUs I ever had.... were the USA MP chrome box with black heat sink, and the standard motor products stock replacement chrome box.
I did have one orange box that worked really well, I used it until it became a rust ball but it refused to die.
All those are still in a box somewhere, as they aren't really worth anything to anyone but could be used in an emergency.
The others I've had that worked all went into cars that were sold off at some point.
I had about a half dozen orange boxes that were garbage, or failed within a few months. None of those even lasted a year in daily driving.
I had one that caused the engine to stall in exactly the same spot, every day on the way home from work.
Every diagnosis known to man was done, no problems found. Swap the box: fixed. Ridiculous.
Now: I wish I had saved a junk one, to hide an HEI module inside.
I had two brand new untested usa orange ecus.... somebody just had to have them, so I sold them as-is/at your own risk.
My take on it is, the vendor cheapened up the product until it was no good anymore. As someone who scrounged up the prints for the old
Direct Connection ECUs, put them on my desk and read them....I can tell you MP had very little say in their demise
except either 1. keep the products 2. kill the products. Eventually they were killed off.
You can blame MP for them being junk if you want to, with the rationale "they made it to MP's specs!". That's also what I would think, if I was on the outside.
But: If you knew exactly what MP's specs did, and (especially) did not consist of back then....you'd probably see what I mean.
I did have a small amount of input on the Gold Box being killed off, but that happened long before the other two.
For me, it's HEI module/Ford TFI coil for low buck upgrades, msd for street/strip.
Rich H.
Esse Quam Videri
Re: Final Nail in the Coffin for the "Orange Box" [Re: ZIPPY] #2815145
08/30/20 03:41 PM
08/30/20 03:41 PM
I like and use the MSD7C boxes on the street until they die up
