Final Nail in the Coffin for the "Orange Box"
#2814232
08/28/20 09:27 AM
08/28/20 09:27 AM
Posts: 179 California, U.S.A.
Torquemonster440
California, U.S.A.
Welp, the newest episode of Engine Masters confirms the age old debate over whether or not the old standard "Orange Box" ignition controller is a worthwhile option in comparison to a modern digital ignition. I've been on the fence about upgrading my ignition recently.Years ago I recurved my distributor at home, it works well but at its core it's at least 20 years old. When paired with my equally old orange box I think I'm at a disadvantage in terms of all out performance, not to mention reliability. Watch the episode if you get a chance, it's a good one. New MSD system... Here I Come.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Final Nail in the Coffin for the "Orange Box"
[Re: mopar dave]
#2814249
08/28/20 10:14 AM
08/28/20 10:14 AM
Posts: 4,705 Wichita
GY3
Wichita
I've used the MSD 6AL with a stock, recurved magnetic pickup Mopar distributor combo for 20 years.
Stone reliable and you can get all the parts at the local parts house.
Having a rev limiter and things like timing control is all the more reason to convert.
[Re: AndyF]
#2814394
08/28/20 02:13 PM
08/28/20 02:13 PM
Posts: 11,742 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Last time I used one of those - a chrome box - Jimmy Carter was president.
[Re: CMcAllister]
#2814410
08/28/20 02:44 PM
08/28/20 02:44 PM
Posts: 34,963 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
i tried a revenator .. did not work for me
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: fastmark]
#2814553
08/28/20 09:55 PM
08/28/20 09:55 PM
Posts: 4,848 Memphis
HemiRick
Memphis
As my cars stock ignitions die, I'm replacing them w hidden GM 4 pin HEI modules.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2814563
08/28/20 10:14 PM
08/28/20 10:14 PM
GY3
Wichita
As my cars stock ignitions die, I'm replacing them w hidden GM 4 pin HEI modules. My neighbor just did this on a Dart he's building. It's a neat setup!
[Re: GY3]
#2814650
08/29/20 10:14 AM
08/29/20 10:14 AM
RapidRobert
[quote=HemiRick]As my cars stock ignitions die, I'm replacing them w hidden GM 4 pin HEI modules. whats the best one to use, an OE black one from the 70's or one of the aftermarket ones?
[Re: AndyF]
#2814866
08/29/20 08:03 PM
08/29/20 08:03 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
I dyno tested some Mopar ignition boxes years ago and they all performed so poorly that I tossed all that stuff and moved on. Above 6000 rpm all the ones I tested had issues. So did Mopar Performance - Tossed Back in the days of Direct Connection , there was actually some pretty good Ignition Boxes along with coils Now try piecing together a decent so called factory oem system using all this Chinese mismatched crap available today It’s truly amazing how many different ECU / Ignition modules / coils fail above 5,000 RPMs In reality FBO is about your only COMPLETE system if you want to stay Inductive
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: AndyF]
#2814893
08/29/20 08:50 PM
08/29/20 08:50 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Be careful. I'm in FB jail for telling the truth about some of the stuff produced by our Far East brothers and sisters. Apparently Mr Z thinks they are great and the things they make are not "C******* trash"..
It's all suspect, even the "good" MSD stuff. Gotta love equity firms.
Not sure I'd consider a 1970s GM solution to be the right answer though.
[Re: CMcAllister]
#2815017
08/30/20 07:27 AM
08/30/20 07:27 AM
Posts: 6,435 Abilene, Texas
fastmark
Abilene, Texas
Not sure I'd consider a 1970s GM solution to be the right answer though. Wow, what ever happened to free speech? It sad how this country seems to be controlled by very few big moguls that think they know the answers to everything and us lowly sheep need to just follow what they think is best for us. Somehow they seem to be the richest, as well. I bet they won’t give up their wealth and share that!
[Re: Torquemonster440]
#2815096
08/30/20 01:04 PM
08/30/20 01:04 PM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
The best Chrysler ECUs I ever had.... were the USA MP chrome box with black heat sink, and the standard motor products stock replacement chrome box. I did have one orange box that worked really well, I used it until it became a rust ball but it refused to die. All those are still in a box somewhere, as they aren't really worth anything to anyone but could be used in an emergency. The others I've had that worked all went into cars that were sold off at some point.
I had about a half dozen orange boxes that were garbage, or failed within a few months. None of those even lasted a year in daily driving. I had one that caused the engine to stall in exactly the same spot, every day on the way home from work. Every diagnosis known to man was done, no problems found. Swap the box: fixed. Ridiculous. Now: I wish I had saved a junk one, to hide an HEI module inside.
I had two brand new untested usa orange ecus.... somebody just had to have them, so I sold them as-is/at your own risk.
My take on it is, the vendor cheapened up the product until it was no good anymore. As someone who scrounged up the prints for the old Direct Connection ECUs, put them on my desk and read them....I can tell you MP had very little say in their demise except either 1. keep the products 2. kill the products. Eventually they were killed off.
You can blame MP for them being junk if you want to, with the rationale "they made it to MP's specs!". That's also what I would think, if I was on the outside. But: If you knew exactly what MP's specs did, and (especially) did not consist of back then....you'd probably see what I mean.
I did have a small amount of input on the Gold Box being killed off, but that happened long before the other two.
For me, it's HEI module/Ford TFI coil for low buck upgrades, msd for street/strip.
Rich H.
Esse Quam Videri
