Re: Who uses Victor heads on a 440?
[Re: Brian Hafliger]
#281399
04/09/09 12:48 PM
04/09/09 12:48 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Mopar and Crane ended up going with .565 offset on P5153899 and 3900 (retail $636 for either pn). I have a set of 3900s, and also a set of the Hughes 1.5s ($595 retail) and Hughes states they're using .600 offset. If I ever get around to using the heads or any of the other paraphenalia I'll let you know how it works out....but as Brian states, I'd expect to check and correct the pushrod clearance in every case. For now I haven't come close enough to seeing the potential of unported rpm heads, let alone Victors....but it's fun to look at all the pretty parts sitting on the shelf I guess
Rich H.
Esse Quam Videri
[Re: Harley]
#281402
04/09/09 01:33 PM
04/09/09 01:33 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
i used the hughes intake rockers on my shafts with my old exhaust rockers and have not had any problems.a little pushrod clearanceing was needed done by fbs63 this was on a low deck with 1.6 rockers and 3/8 push rods
WAXER
[Re: Harley]
#281403
04/09/09 03:39 PM
04/09/09 03:39 PM
Posts: 31,115 Oregon
AndyF
Would Indy 440-1 rockers work on the victor heads?
Maybe the offset would be correct but I think the standard Mopar rocker arms are actually a little too long for the Victor head. The Victor head is taller than a production head so the pushrods and valves are both longer. Since those two items are at an angle to each other as they get longer the distance between them gets shorter.
[Re: hot67cuda]
#281407
04/09/09 09:53 PM
04/09/09 09:53 PM
Posts: 166 Ames, Iowa
LoneMopar
Ames, Iowa
I am going to try some Victors this year. I'll post some results in a couple weeks. Here's a pic with Hughes rockers .600 offset. The heads needed a fair amount of pushrod clearancing. .750 offset rockers would really make a lot of pushrod angle. My next set of roller lifters will be offset!
[Re: QWK_ENUF]
#281410
04/10/09 10:10 AM
04/10/09 10:10 AM
Posts: 3,210 robin hood country
deaks
robin hood country
How much higher would a 440 need to rev, to get the most out of the victors, compared to a larger engine.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
