A body sliders #2812774
08/24/20 07:58 PM
08/24/20 07:58 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Just curious, I didn't see any on the internet, but does anyone make sliders for a A body mopar the will bolt on to the stock rear shackle mounting holes?
Scott
Re: A body sliders [Re: maxie] #2812809
08/24/20 09:05 PM
08/24/20 09:05 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Any of the kits I have seen are welded to the rail.
Alan Jones
Re: A body sliders [Re: LA360] #2813118
08/25/20 03:36 PM
08/25/20 03:36 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Calvert makes sliders that might be able to be bolted on to the rear longitudinal, at least they have holes in them.
However I think I would want them welded.
Re: A body sliders [Re: 340Cuda] #2813153
08/25/20 04:59 PM
08/25/20 04:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If I ever go sliders there will be a plate welded to the frame with the sliders bolted to it.
Re: A body sliders [Re: justinp61] #2813165
08/25/20 05:30 PM
08/25/20 05:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
A friend did this on his altered wheelbase car and it works great.
'63 Dodge 330
11.19 @ 121 mph
Re: A body sliders [Re: GY3] #2813210
08/25/20 06:52 PM
08/25/20 06:52 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
was just out there looking under the car, the tech from calvert said weld them to the frame rail, can't do that my springs are in stock location. Looks like I would need to weld a plate to the frame rail and the box that the original rear shackle mounts to along with a gusset.
my car 1.76 sixty foots with the caltracs and i need to dial them in, just didn't know if the sliders were worth the effort, was hoping to find something that was already prefabbed for them
Re: A body sliders [Re: maxie] #2813459
08/26/20 09:38 AM
08/26/20 09:38 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
i got them on my barracuda
Re: A body sliders [Re: one bad fish] #2813471
08/26/20 09:52 AM
08/26/20 09:52 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While I am sure there are folks that use the Calvert sliders on the street, Calvert does not recommend that.
Re: A body sliders [Re: maxie] #2813491
08/26/20 10:52 AM
08/26/20 10:52 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Sliders won't be a fix all for your 60 ft.
I run poly bushings in stock shackles and the car has been 1.37 60 ft.
'63 Dodge 330
11.19 @ 121 mph
Re: A body sliders [Re: GY3] #2813524
08/26/20 11:55 AM
08/26/20 11:55 AM
bronx n.y
O
O
bronx n.y
i wont say its a fix but it helps
Re: A body sliders [Re: one bad fish] #2813600
08/26/20 03:32 PM
08/26/20 03:32 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I learned that I have them completely loaded backwards. I have preload on the passenger side and none on the drivers side. Have also read where people are running a nickel wide gap with no preload.
I footbrake my car.
Re: A body sliders [Re: maxie] #2813620
08/26/20 04:17 PM
08/26/20 04:17 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I footbrake my car.
This
Make sure your front pivot is loose and moves freely too.
I've seen guys that have issues with Cal-Tracs having stuff too tight and it binds. I also have the solid front aluminum bushings in the spring eye.
'63 Dodge 330
11.19 @ 121 mph
Re: A body sliders [Re: GY3] #2813632
08/26/20 05:02 PM
08/26/20 05:02 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I footbrake my car.
This
so where the bolt goes through the front eye should not be tightened by king kong, And then the other pivot point.
I am notorious for doing that. I don't recall a torque spec on that.
I also have the aluminum eye in there and put anti seize on it.
Re: A body sliders [Re: maxie] #2813638
08/26/20 05:17 PM
08/26/20 05:17 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
so I guess where the hemi joints have the bolts going through make sure that the hemi joints can we say swivel? On both ends of the adjustable bar
Re: A body sliders [Re: maxie] #2813647
08/26/20 05:45 PM
08/26/20 05:45 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Everything should be free'd up and articulate easily. We use locking nuts on the front hardware so there is no "torque spec".
'63 Dodge 330
11.19 @ 121 mph
Re: A body sliders [Re: GY3] #2814351
08/28/20 01:02 PM
08/28/20 01:02 PM
moparx Offline
moparx  Offline
when using solid bushings or solid heims, tighten up until there is no slop, then "maybe" 1/4 turn [?] using a quality locking nut.
that will depend on your preference of the feel of movement without drag or slop.
a liberal amount of anti-seize [without slobbering it everywhere] should be used on the bolt and bushing as well.
beer
Re: A body sliders [Re: moparx] #2814441
08/28/20 04:05 PM
08/28/20 04:05 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
My street/strip bracket cars 60-s in the high 1.30s and I wanted to keep a oem look.
I built boxes out of smaller 2x2 square stock and welded to frame where shackle mount would of been bolted.
You could easily make a 1 inch spacer vs my 4 inch and weld slider to spacer and already have your "spacer" fabded and drilled to your shackle mount pattern, and bolt them on.
These have worked flawless for 16 years.
Sliders won't be a fix all for your 60 ft. True, but sliders and good double adjustable shocks mounted vertically do a good bit.
STOP POTATO HATE!
Re: A body sliders [Re: Mr PotatoHead] #2815137
08/30/20 02:50 PM
08/30/20 02:50 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I ordered the A body spring relocation kit from Mancini and I will use the piece that goes in the front frame rail as the piece the slider will bolt to. I ordered a piece that was recommended on FORABODIESONLY but I haven't received it, not have the sent it. They have my order as pending. It was a body to frame mounting bracket for a FJ40 toyota land cruiser.
