my one buddy has a 58 impala [and yes, i blame any and ALL his problems on his make of choice !
![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
] with a somewhat odd steering feel, if you will, at center, going down the road.
it is always tight, and if you make a slight correction, as is necessary, it seems to want to keep making that correction, thereby forcing you to correct in the opposite direction.
in other words, you are always "driving" the car, which gets very tiresome quickly.
this car has a new 500 series power box [3 1/2 turns lock to lock], along with ball joints, tierod ends, idler arm and ALL bushings, front and rear.
there is absolutely no slop anywhere.
it has 6 degrees of caster [average], negative camber, and 1/8" toe in.
we have loosened up the adjuster on the top of the box three turns, but saw no difference.
this phenomenon is apparent at all speeds, on most road surfaces, and since the box is lots quicker than the manual box it replaced, gets pretty "interesting" at interstate speeds.
there are new tires on it, but this was present with the old ones as well.
we are leaning toward suspecting the box having a problem, but are baffled as well, as this is not our first time converting early GM vehicles to power steering.
what are we missing here ?
the alignment sheet is attached.
Thanks in advance guys !
![bow bow](/ubbthreads/images/graemlins/custom/bow.gif)
our OLD eyeballs and brains are getting worse by the day it seems.
![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
